I have got a PI3 with clean raspbian lite install on a WD Pidrive. This is why I can’s use the hasio image.
I tried installing from the manual install but the sudo pip3 install homeassistant fails:
Running setup.py (path:/tmp/pip-build-ao5p8foz/aiohttp/setup.py) egg_info for package aiohttp
aiohttp/_http_parser.pyx: cannot find cimported module ‘.’
File “”, line 17, in
File “/tmp/pip-build-ao5p8foz/aiohttp/setup.py”, line 59, in
txt = (here / ‘aiohttp’ / ‘init.py’).read_text(‘utf-8’)
AttributeError: ‘PosixPath’ object has no attribute ‘read_text’
Complete output from command python setup.py egg_info:
Cleaning up…
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-ao5p8foz/aiohttp
Storing debug log for failure in /root/.pip/pip.log
