Hoping someone can point me in the right direction.
I have Ollama setup and functional. Whisper can hear and translate speech into text, piper see’s the result from Ollama but is unable to speak the result.
I see an error in the logs that says that because piper (really python, I think) can’t find a local SSL cert (lets encrypt is installed with a cert from Cloudflare) that it can’t download any voices. No voice => no speech output.
Below is my Piper log.
I have tried uninstalling/installing Ollama, Piper/Whisper without any improvement. I’ve looked all over and I can find a few mentions of folks with similar issues in the past but no usable solutions.
I think voices are downloaded from hugginface.co and I can easily access it from the vlan where HA and Ollama/OpenwebUI are hosted.
I don’t think it should matter but here’s my setup:
Everything is running in Proxmox
-HA and Ollama/OpenWebUI are on the same vlan but in separate LXCs. There are not firewall rules that prevent access from one to the other.
-There are no firewall rules that prevent HA from accessing the internet
I am using Satellite 1 boards from Future Proof Homes as my satellites
Thanks for any pointers you may have!
Piper Log:
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:992)>
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name=‘wyoming event handler’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=VoiceNotFoundError(‘en_US-kristin-medium’)>
File “/usr/local/lib/python3.11/dist-packages/wyoming/server.py”, line 41, in run
if not (await self.handle_event(event)):
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py”, line 137, in handle_event
raise err
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py”, line 120, in handle_event
await self._handle_synthesize(self._synthesize)
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py”, line 196, in _handle_synthesize
model_path, config_path = find_voice(
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/download.py”, line 186, in find_voice
raise VoiceNotFoundError(name)
wyoming_piper.download.VoiceNotFoundError: en_US-kristin-medium
