Piper TTS will not work at all
Even in “Try” in the Voice assistant setup… I get nothing. This was in the logs
socket.gaierror: [Errno -5] No address associated with hostname
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/download.py”, line 155, in ensure_voice_exists
urlopen(_quote_url(file_url)) as response,
File “/usr/lib/python3.11/urllib/request.py”, line 216, in urlopen
return opener.open(url, data, timeout)
File “/usr/lib/python3.11/urllib/request.py”, line 525, in open
response = meth(req, response)
File “/usr/lib/python3.11/urllib/request.py”, line 634, in http_response
response = self.parent.error(
File “/usr/lib/python3.11/urllib/request.py”, line 557, in error
result = self._call_chain(*args)
File “/usr/lib/python3.11/urllib/request.py”, line 496, in _call_chain
result = func(*args)
File “/usr/lib/python3.11/urllib/request.py”, line 749, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File “/usr/lib/python3.11/urllib/request.py”, line 519, in open
response = self._open(req, data)
File “/usr/lib/python3.11/urllib/request.py”, line 536, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File “/usr/lib/python3.11/urllib/request.py”, line 1391, in https_open
return self.do_open(http.client.HTTPSConnection, req,
File “/usr/lib/python3.11/urllib/request.py”, line 1351, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno -5] No address associated with hostname>
INFO:main:Ready
[08:08:09] INFO: Successfully send discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
INFO:wyoming_piper.download:Downloaded /data/en_US-amy-medium.onnx.json (https://huggingface.co/rhasspy/piper-voices/resolve/main/en/en_US/amy/medium/en_US-amy-medium.onnx.json)
ERROR:wyoming_piper.download:Unexpected error while downloading files for en_US-amy-medium
File “/usr/lib/python3.11/urllib/request.py”, line 1348, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File “/usr/lib/python3.11/http/client.py”, line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1037, in _send_output
self.send(msg)
File “/usr/lib/python3.11/http/client.py”, line 975, in send
self.connect()
File “/usr/lib/python3.11/http/client.py”, line 1447, in connect
super().connect()
File “/usr/lib/python3.11/http/client.py”, line 941, in connect
self.sock = self._create_connection(
File “/usr/lib/python3.11/socket.py”, line 827, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File “/usr/lib/python3.11/socket.py”, line 962, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
raise URLError(err)
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name=‘wyoming event handler’ coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=VoiceNotFoundError(‘en_US-amy-medium’)>
File “/usr/local/lib/python3.11/dist-packages/wyoming/server.py”, line 41, in run
if not (await self.handle_event(event)):
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py”, line 137, in handle_event
raise err
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py”, line 111, in handle_event
await self._handle_synthesize(self._synthesize)
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py”, line 196, in _handle_synthesize
model_path, config_path = find_voice(
File “/usr/local/lib/python3.11/dist-packages/wyoming_piper/download.py”, line 186, in find_voice
raise VoiceNotFoundError(name)
wyoming_piper.download.VoiceNotFoundError: en_US-amy-medium
Problems with HF availability, unable to download the model. Please try again later.
What is HF?
hugging face
