I’m still in the “overwhelmed” phase of my HA discovery. But it’s promising. IE, my wife loves the “cat needs to pee” automation that open one of the cover just enough to let the beast out at 7am.
I’m facing a problem though. I’m trying to use some Neo Coolcam Z-wave PIR sensors as perimetric security devices. The goal is to get an alert if someone triggers the PIR around my house during night, or while we’re not home. But so far, I do not get any notifications…?
I created 3 test automations:
- id: '1637164944247'
alias: PIR test
description: ''
- platform: state
entity_id: binary_sensor.pir_motion_sensor_2_home_security_motion_detection
to: Detected
condition:
- condition: time
after: '13:00'
before: '21:00'
- service: notify.mobile_app_kamobile_xi
message: PIR TEST
mode: single
- id: '1637164942422'
alias: PIR night alert
platform: state
entity_id:
- binary_sensor.pir_motion_sensor_1_home_security_motion_detection
- binary_sensor.pir_motion_sensor_3_home_security_motion_detection_2
- binary_sensor.pir_motion_sensor_3_home_security_motion_detection_3
to: Detected
- condition: time
state:
- after: '13:00'
- before: '19:35'
- service: notify.Home-Alert
message: Perimeter alert!
I checked the notifications system, it’s working when I trigger it by hand from the dev.tool section.
The device trackers are okay, the bin sensors as well and they do report state as either Detected or Clear.
Binary sensors are either ‘on’ or ‘off’, but you used ‘Detected’ and ‘Clear’. These are the states in the frontend and they are based on your language setting and the device class of the binary sensor.
The “true” states can be found under Developer Tools → States, these are the ones you need to use in the automation.
Ok makes total sense, thx a lot. I fixed my automation, but still no luck.
I tried with just one notifier (in case) and with all of them but I don’t get anything so far, neither in pushover (notify.info/alert), app nor in MQTT. Like if it was not triggered. I removed the time also in 1st automation to avoid unnecessary variables.
I checked in the dev.tools and the PIRs are indeed changing states from off to on.
platform: state
entity_id:
- binary_sensor.pir_motion_sensor_2_home_security_motion_detection
to: on
- service: notify.home_alert
message: "Perimeter alert!"
- id: '1837164947747'
alias: PIR OOH alert
platform: state
entity_id:
to: on
- delay: 00:01:00
- condition: state
entity_id:
- device_tracker.kamobile_xi_2
state: not_home
- service: notify.home_info
- service: notify.notify
Ok I had to quote ‘on’ and ‘off’, my bad, thanks a lot.
I also had a mistake in the state and the data payload needs to be precised per notification service.
