PIR sensor dsappeared
I have a Zwave pir sensor available in openzwave but not in HASS.
How to fix this?
  1. Check your OZW_log whether it’s not considered dead.
  2. Run a Z-wave heal
  3. Remove zwcfg_xxxxxx.yml from homeassistant’s configuration folder and restart hass
Thanks will try it
where is this?
EDIT found in hass directory: file is very very big, don’t know what to look for
no, not working this way.
What else can I try?
Do the following:
delete the OZW_log file
restart hass, and immediately do:
tail -f OZW_log.txt
look for lines that have “Error” in them, e.g.:
 2017-04-19 12:32:39.577 Error, Node005, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
Notice the Node005 - this is the Z-wave that is having connection troubles.
Also don’t forget to delete your home-assistant.log and the OZW_log.txt files. I personally keep mine in a tmpfs to not overuse the SD Card, as it can easily get corrupted, but this is somewhat advanced topic and can have wipe out your installation.
I have this error
pi@raspberrypi:/home/hass/.homeassistant $ dir
alexa_confirm.yaml     home-assistant.log             pyozw.sqlite
automation.yaml        home-assistant_v2.db           RMTasker
automazionidaniel.txt  html5_push_registrations.conf  script.yaml
broadlink              ID\ Hue.txt                    secrets.yaml
broadlinkNUOVO2.py     input_select.yaml              sensor
broadlinkNUOVO.py      known_devices.yaml             show_lights.py
configuration.yaml     netatmoGIUSTO.py               sonoff.txt
custom_components      nuovi-componenti               ThermostatGIUSTO.py
customize.yaml         old\ switches.txt              toggle_corridor.py
deps                   OZW_Log.txt                    tts
emulated_hue_ids.json  panels                         www
example_tts.py         phue.conf                      zwcfg_0xfd325151.xml
fitbit.conf            pictures                       zwscene.xml
google_calendars.yaml  plex.conf
pi@raspberrypi:/home/hass/.homeassistant $ tail -f OZW_log.txt
tail: cannot open ‘OZW_log.txt’ for reading: No such file or directory
tail: no files remaining
in the log is this
2017-04-21 10:08:09.554 Detail,
2017-04-21 10:08:09.554 Detail, Node003, Removing current message
2017-04-21 10:08:09.555 Detail, Node003, Notification: Notification - NoOperation
2017-04-21 10:08:09.562 Detail,
2017-04-21 10:08:09.562 Info, Node005, Sending (NoOp) message (Callback ID=0x0c, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xcb
2017-04-21 10:08:09.570 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-04-21 10:08:09.570 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2017-04-21 10:08:13.799 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x01, 0x01, 0xa7, 0x40
2017-04-21 10:08:13.800 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2017-04-21 10:08:13.800 Info, Node005, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-04-21 10:08:13.800 Info, Node005, Node 5 has been marked as asleep
2017-04-21 10:08:13.800 Info, Node005, Node not responding - moving QueryStageComplete command to Wake-Up queue
2017-04-21 10:08:13.800 Detail, Node005, Notification: Notification - NoOperation
2017-04-21 10:08:13.819 Detail, Node005, Notification: Notification - Node Asleep
2017-04-21 10:08:13.827 Info, Deleting all return routes from node 3
Which one is your PIR?! Is it Node003 or Node005?
Node 005 is asleep so if this is your PIR and it is running on batteries it could take a while to poll and fetch its data.
If it is 003 - I think there’s an issue with connecting to it - run z-wave/heal multiple times.
The Node3 is working fine.
The problem is Node005. And is like this since 24 hours
First is Node5 (the PIR sensor with problems)
Second is Node 1 (the stick)
Third is Node2 (the other PIR sensor, working)
Fourth is Node3 the power plug, which works
try to wake it up. See in the sensors’ manual how to wake it up and keep it awake for some time until it’s refreshed by hass.
