PIR sensor, timer delay help
I am using a PIR with 8266-01s, to activate a switch, wait for 30 seconds, then deactive the switch.
I am confused about PIR / timer re-enter problem:
If the switch is activated, and in 30 seconds, another PIR is detected again, the behaviour is strange, the delay of the switch is uncertain.
I tried to use a global variant to identify the status of in previous timer, but it does not work.
Please help, thank a lot.
Here is my template:
substitutions:
  hostname: '8266-01s'
esphome:
  name_add_mac_suffix: true
# ESP 01s
esp8266:
  board: esp01_1m
  framework:
    version: recommended
# Enable logging
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: '$hostname Hotspot'
    password: "pass"
# Enable Home Assistant API
api:
  password: !secret api_password
ota:
  password: !secret ota_password
# Enable logging
logger:
captive_portal:
# Begin
# if the switch is turned manually
globals:
  - id: gManual
    type: int
    restore_value: no
    initial_value: '0'
  - id: gInTimer
    type: int
    restore_value: no
    initial_value: '0'
switch:
  - platform: gpio
    pin: GPIO0
    inverted: true
    lambda: 'return id(gManual) == 1;'
    turn_on_action:
      - logger.log: 'gManual ==> true'
      - switch.turn_on: gpio_0
      - lambda: |-
          id(gManual) = 1;
    turn_off_action:
      - logger.log: 'gManual ==> false'
      - switch.turn_off: gpio_0
      - lambda: |-
          id(gManual) = 0;
  - platform: restart
  - platform: wifi_signal
    name: '$hostname WiFi Signal'
    update_interval: 60s
binary_sensor:
  - platform: status
  - platform: gpio
    device_class: motion
    pin:
      number: GPIO2
      mode:
        input: true
        pullup: true
    on_state:
      then:
        - if:
            # PIR is triggered?
            condition:
                binary_sensor.is_on: thisPIR
            then:
              - if:
                  # Is in manual mode?
                  condition:
                  then:
                    logger.log: 'gManual is true, ignore PIR.'
                  else:
                    - if:
                        # Is still in previous timer?
                        condition:
                            lambda: 'return id(gInTimer) == 1;'
                        then:
                          - logger.log: 'Still in previous timer, ingore PIR.'
                        else:
                          - lambda: |-
                              id(gInTimer) = 1;
                          - logger.log: 'gManual is false, using PIR.'
                          - delay: 30s
                          - lambda: |-
                              id(gInTimer) = 0;
                          - logger.log: 'Time is off, turn off gpio_0.'
I may found the reason:
  1. When using GPIO2 as PIR pin, it is connected to Vcc, so, it will be high, thus will like PIR detected.
  2. Switch go GPIO3, then set pullup=false, to make sure it is low when not use.
