Thankyou @jtjart for making it configurable from the GUI and also fixing the library so it works with a lot more projectors.
It is nice finally having it rocksolid instead of having to patch it on every boot because of upstream issues.
If you meant this to be a direct message, it didn't work.
@Sir_Goodenough , this was intentional ![]()
You do understand that there is no backstory for your initial post in this thread? Threads are designed to pose questions that need resolutions to assist others users. If your OP was intentional, it may be beneficial to add content. If not, DM the user or communicate via your YT channel...
Let me add some context then,.this problem was raised multiple times on github, only to be dismissed just as many, then a clever guy (which pr. definition is not me) found a patch for the problem, which until it was implemented in HA, had to be run after every update or boot, it was still dismissed.
So despite the fact that pjlink was listed as an integration, it didn't work. And despite that, the integration was not marked as defective.
Now it has been fixed, and that is cause for celebration!
