Hi experts, i need your help!
I’m currently using esphome and an ESP32 to monitor the plant-sensor from Xiaomi (MiFlora).
My esphome config looks like documented here:
To support the plant-UI, i have the following mapping in the config:
plant:
plant1:
sensors:
moisture: sensor.flower1_moisture
temperature: sensor.flower1_temperature
conductivity: sensor.flower1_soil_conductivity
brightness: sensor.flower1_illuminance
min_moisture: 20
This setup leads to the following Issue:
Every time the ESP reports new values to home-assist and the value-set does not contain new values for each of my five sensors, some of my sensors switch to “Unavailable”, until they eventually report new values.
The UI then looks like this:
Is there any option/workaround to use the last-valid value to display?
I could not find any solution yet.
Thanks for your help!
