I get an error since latest update of Home assistant and i dont understand how to fix it, I am trying to get the CPU temperature:
- platform: command_line
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp" unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) |round(1) }}'
Results in error:
Configuring the command_line integration by adding platform: command_line under the sensor: key is not supported. The command_line integration must be configured under its own command_line: key instead.
To resolve this:
Remove the following from your YAML configuration file:sensor: - platform: command_line
Move the configuration under the command_line: key instead.
Restart Home Assistant.
