from this morning the xiaomi-aqara platform seems to be no longer working. I have 2 hassio on my network and both seem to have this problem. Has anyone else detected this error?
I also tried to renew the tokens but I still have the same problem
this is the log>
2019-04-21 21:31:16 INFO (SyncWorker_3) [xiaomi_gateway] Discovering Xiaomi Devices 2019-04-21 21:31:16 DEBUG (SyncWorker_3) [xiaomi_gateway] _send_cmd >> b'{"cmd" : "get_id_list"}' 2019-04-21 21:31:17 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.workday 2019-04-21 21:31:20 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 154, in _async_setup_component component.setup, hass, processed_config) # type: ignore File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.7/site-packages/homeassistant/components/xiaomi_aqara/__init__.py", line 134, in setup xiaomi.discover_gateways() File "/usr/local/lib/python3.7/site-packages/xiaomi_gateway/__init__.py", line 112, in discover_gateways resp["proto_version"] if "proto_version" in resp else None) File "/usr/local/lib/python3.7/site-packages/xiaomi_gateway/__init__.py", line 215, in __init__ if self._discover_devices(): File "/usr/local/lib/python3.7/site-packages/xiaomi_gateway/__init__.py", line 222, in _discover_devices resp = self._send_cmd(cmd, "get_id_list_ack") if int(self.proto[0:1]) == 1 \ File "/usr/local/lib/python3.7/site-packages/xiaomi_gateway/__init__.py", line 320, in _send_cmd resp = json.loads(data.decode())
