PlatformIO hangs while downloading platform in ESPHome Add-on
When compiling a project for ESP8266 (D1 Mini) in the ESPHome Add-on (v2025.10.3), PlatformIO hangs while downloading the platform:
Processing washer-sound-detector (board: d1_mini; framework: arduino; platform: espressif8266)
Platform Manager: Installing espressif8266
Downloading  [------------------------------------]    0%
  • PlatformIO Core: 6.1.18
  • The issue occurs even when specifying a specific platform version ([email protected] or 4.2.3).
  • About 3 months ago, the same project compiled successfully with the same configuration.
  • Minimal YAML configuration:
esphome:
esp8266:
  board: d1_mini
Question:
Why does PlatformIO hang while downloading the platform inside the Add-on, and how can I compile the firmware successfully without this hang?
Thank you for your assistance.
Hello everyone.
I have a similar problem. Has anyone solved it?
I’ve rolled back everything to previous versions, reinstalled, uninstalled, reinstalled, and nothing helps!
Please let me know if anyone has a solution!
I migrated the system from HA Supervised to HAOS and got a similar problem.
ESPHome cannot download Platformio.
So far, I have found only one option, to specify an alternative Platformio path.
esphome:
  platform: ESP8266
  board: d1_mini
  platformio_options:
    platform: https://github.com/platformio/platform-espressif8266.git
However, after being added to working projects, some libraries also do not load.
As I understand it, this is related to blocks imposed by specific providers. In my case, it’s MTS mobile network.
When downloading, ESPHome connects to the address 88.198.170.159:443.
The DNS is working — it resolves the address to an IP, but ping to this address fails. This indicates blocking.
88.198.170.159:443 → https://dl.registry.platformio.org
The website defined in ESPHome settings maps to this IP address.
The same problem.
There is an option to reassign the library path, but I didn’t quite get it.
https://esphome.io/components/esphome/#esphome-libraries
INFO ESPHome 2025.10.4
INFO Reading configuration /config/esphome/fastled.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing fastled (board: esp01_1m; framework: arduino; platform: https://github.com/platformio/platform-espressif8266.git)
Removing unused dependencies...
Library Manager: Installing git+ESP32Async/ESPAsyncTCP=https://github.com/ESP32Async/ESPAsyncTCP.git
INFO Installing git+ESP32Async/ESPAsyncTCP=https://github.com/ESP32Async/ESPAsyncTCP.git
git version 2.39.5
Cloning into '/data/cache/platformio/cache/tmp/pkg-installing-30ddtqn1'...
fatal: protocol 'ESP32Async/ESPAsyncTCP=https' is not supported
VCSBaseException: VCS: Could not process command ['git', 'clone', '--recursive', '--depth', '1', 'ESP32Async/ESPAsyncTCP=https://github.com/ESP32Async/ESPAsyncTCP.git', '/data/cache/platformio/cache/tmp/pkg-installing-30ddtqn1']
