Play Audio node in Node-RED not working after Home Assistant upgrade
I have a simple flow in my Node-RED that sends a tone to the PC speaker. It gives an audible alert that a “Deploy” is finished. It worked fine before upgrading from 0.72, but now it doesn’t. Has anyone else used the Play Audio node?
[{"id":"a1d47414.fdf2e8","type":"inject","z":"11ef03a7.e4b69c","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":230,"y":160,"wires":[["1d60349d.565deb"]]},{"id":"1d60349d.565deb","type":"file in","z":"11ef03a7.e4b69c","name":"Reads Unlock.wav","filename":"/config/node-red/lib/sounds/Unlock.wav","format":"","chunk":false,"sendError":false,"x":470,"y":160,"wires":[["2a6a1b7f.727f14"]]},{"id":"2a6a1b7f.727f14","type":"play audio","z":"11ef03a7.e4b69c","name":"","voice":"0","x":710,"y":160,"wires":[]}]
Try upgrading Node-RED, I think 19.5 is the latest version
There is no upgrade- I just upgraded everything including my add-on’s when this problem occurred.
Still puzzled. The Play Audio node is working. I can send it text and it will convert it to speech. I also verified the wav file location.
Question- In HassOS, who owns Node-Red? The wav file is currently owned by root, so I am wondering if that might be the problem?
