Play Stream Nest Cam Wired not working
I have a Nest Cam Wired (new gen) which streams fine in Lovelace however if I try to stream it to a media player (e.g. Nest Display) using the camera.play_stream services it is not working. It’s also not listed under Media → Camera but again streams fine within HA. Exact same setup works perfectly with a Nest Hello Doorbell. Based on my research, the new Nest Cam Wired use WebRTC as opposite to RTSP with the older Nest Hello camera however I do have the latest HA version that I believe supports WebRTC.
I am missing anything? Thanks in advance for any help
That service is not supported for webrtc cameras. (See the docs for more details)
