Hi everybody,
I built this by using the example provided in the mobile companion docs. For some reason I cannot figure out myself, the action that is supposed to happen via notify.mobil
(input_boolean.turn_on
) does not happen.
Can you please help me with this?
automation:
### This will turn OFF an input_boolean in order to
### trigger the ALERT that I initially used for this
- alias: "Notify Helper Vacuum Off"
- platform: time
at: input_datetime.helper_medusa_check
- service: input_boolean.turn_off
entity_id: input_boolean.helper_medusa_oben
### This gets triggered by said input_boolean
- alias: "Mobile: Medusa Oben"
- platform: state
to: "off"
mode: single
- alias: "Bis sie oben ist wiederholen"
repeat:
sequence:
# inside a automation actions or script sequence
- alias: "Variabeln festlegen"
variables:
# Including an id in the action allows us to identify this script run
# and not accidentally trigger for other notification actions
action_erledigt: "{{ 'ERLEDIGT_' ~ context.id }}"
action_close: "{{ 'CLOSE_' ~ context.id }}"
### FIRST, clear any notifications with this TAG that
### might already exist (as they'd be identical; this tag is only used once)
- service: notify.mobil
message: "clear_notification"
tag: medusahoch
- delay:
seconds: 2
### THEN, send the next notification
message: "Bitte Medusa nach oben holen."
actions:
- action: "{{ action_erledigt }}"
title: Erledigt
tag: medusahoch
- delay:
minutes: 15
### I assumed THIS and the delay above would assure that
### the automation would repeat UNTIL that input_boolean
### would be turned ON again (which is supposed to
### be handled by this part from above
### => action_erledigt: "{{ 'ERLEDIGT_' ~ context.id }}"
### in the automation below
until:
- condition: state
state: "on"
### THIS automation
- alias: "Auf die Antwort warten"
wait_for_trigger:
- platform: event
event_type: mobile_app_notification_action
event_data:
# waiting for the specific action avoids accidentally continuing
# for another script/automation's notification action
- platform: event
event_data:
action: "{{ action_close }}"
- alias: "Perform the action"
choose:
- conditions: "{{ wait.trigger.event.data.action == action_erledigt }}"
sequence:
### specifically, THIS part here:
### I just kept this from the example;
### it doesn't do anything at all, and it cannot even be triggered
### BY clicking anything, as I removed that part from above
- conditions: "{{ wait.trigger.event.data.action == action_close }}"
sequence:
- service: cover.close_cover
entity_id: cover.some_cover
In order to test this, I manually turned off input_boolean.helper_medusa_oben
. When I did, the service: notify.mobil
positively did get triggered. The notification showed up on my device (and supposedly on other devices as well, which I wasn’t able to check at the time).
When I clicked on Erledigt
underneath the notification on my Android device, I could see that an Event
did show up in Home Assistant (the data
part contained something like ERLEDIGT_21342345634345435
, or similar).
However, the input_boolean.helper_medusa_oben
did not turn_on
, and the notification would re-occur every 15 minutes. I now manually turned it on through lovelace, but still got the notification again a few minutes ago (after turning it on, of course).
Can you please tell me what I did wrong? It should not repeat once the input_boolean is on
again, but it did at least once. It should also act accordingly to the event
fired when I clicked Erledigt
underneath the Android notification, this turning that input_boolean on.
Thank you in advance for your help
