Please recommend a smart wall switch that allows independent use of the button and relay
Hi! I want a wall switch in my room to switch on different lamps depending on the time of a day. I want the switch to look identical to other switches in my flat, so I need a device like Sonoff ZBMINI (-L), so that I can mount it behind the existing switch. The problem with ZBMINI is that it always toggles the relay when you press the switch button. For my scenario in the evening I don’t want to switch the main light, when the button is pressed.
Do you know any similar device that can act as a relay and as a button independently? Ideally with Zigbee connection. Ideally the one that available in the EU. Versions with and without the neutral wire works.
There’s shelly and the latest sonoff mini r4, both are wifi relay modules that comes with decoupled mode on the stock firmware
For zigbee, there’s aqara h1/e1 but they’re wall switches.
Thank you for the answer! Talking about the firmware: is it possible to install some custom firmware to a ZigBee version of Sonoff device to decouple the switch?
I am afraid that different IoT devices in your Wi-Fi network can slow it down…
For zigbee no, mostly for wifi devices
Sad to hear, but thank you anyways!
Hello @Paboka , which relay did you end up going with in the end?
