root@gkitc:~# cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
root@gkitc:~# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 108.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2711
Revision : b03115
Serial : 10000000b904b08c
Model : Raspberry Pi 4 Model B Rev 1.5
root@gkitc:~# l
total 2620
-rw-r--r-- 1 root root 565 Apr 13 02:00 .bashrc
drwx------ 2 root root 4096 Feb 21 10:09 .cache
-rw-r--r-- 1 root root 6444 Mar 3 07:31 homeassistant-supervised.deb
-rw-r--r-- 1 root root 2651728 Mar 17 01:15 os-agent_1.5.1_linux_armv7.deb
I've tried several times, but I always get an error here
What am I not aware of,
What am I doing wrong?
Teach me
root@gkitc:~# dpkg -i homeassistant-supervised.deb
[error] Raspbian GNU/Linux 11 (bullseye) is not supported!
dpkg: error processing archive homeassistant-supervised.deb (--install):
new homeassistant-supervised package pre-installation script subprocess returned error exit status 1
[info] Undo divert on abort-install
No diversion 'diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised', none removed.
No diversion 'diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised', none removed.
[info] Resetting debconf selections
[info] Removal complete, due to the complexity of this installation method,
[info] you will need to manually remove the containers created by the supervisor
Errors were encountered while processing:
I tried another
stop here
No response.
pi@gkitc:~ $ sudo -i
root@gkitc:~# curl -sL "https://raw.githubusercontent.com/Kanga-Who/home-assistant/master/supervised-installer.sh" | bash -s -- -m raspberrypi4-64
[info]
[info] This script is taken from the official
[info]
[info] Home Assistant Supervised script available at
[info]
[info] https://github.com/home-assistant/supervised-installer
[info]
[warn] ModemManager service is enabled. This might cause issue when using serial devices.
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
[warn] Docker is using and not 'overlay2' as the storage driver, this is not supported.
[warn] Docker is using and not 'journald' as the logging driver, this is not supported.
[info] Creating NetworkManager configuration
[warn] Changes are needed to the /etc/network/interfaces file
[info] If you have modified the network on the host manualy, those can now be overwritten
[info] If you do not overwrite this now you need to manually adjust it later
[info] Do you want to proceed with overwriting the /etc/network/interfaces file? [N/y]
y
[info] Replacing /etc/network/interfaces
[info] Restarting NetworkManager
First step: change the post heading to…
Teach me how to install Supervised Home Assistant Home Assistant Supervised on Rpi4 using RaspiOS (64-bit)
Do you use the same IP as the one you use for ssh ?
Are you using the same IP you use for ssh?
same.
192.168.0.252
