I’ve added the Plex Activity Sensor to my config in order to see if someone is using Plex, which runs on my pc. Since the pc is close to my bedroom, I always turn it off at night via an automation, but I want it to wait for Plex to become inactive for 5 minutes.
That part works, but when my pc is turned off, the Plex sensor is spamming the HA log with errors about being unable to connect to my pcs ip-address and timeouts while doing so. It checks the status every 30 seconds, so that adds up fast.
Also, when I restart Home Assistant, the Plex sensor won’t load if the pc is not turned on and I’m not sure if it tries again at a later time.
I was wondering if it is possible to stop a sensor from updating based on some conditions, or to turn these updates on or off via an automation. I’ve tried changing the scan_interval, but unless there is a way to do this dynamically or with an automation, this will be of no use to me.
Any tips?
