Plex addon
Hi, I installed the Plex Media Server addon in Hassio. My configuration is:
“log_level”: “info”,
“claim_code”: “claim-**********************************”,
“webtools”: true
and in configuration.yaml
media_player:
  • platform: plex
    host: xxx.xxx.xxx.xxx
The log is:
[services.d] starting services
INFO: Starting the Plex Media Server
[services.d] done.
I think the configuration is correct, but I can not see the plex controls in the main panel. Any help?
Thank’s!
You installed Plex Media Server so it’s normal you don’t get control !! You have to access it at ip-of-your-system:32400 and you should get access at Plex Media Server web interface ! If you want control/feedback of what’s happening on a web server you have to install the buggy Plex component in HA :wink:
If you use the media-control card with lovelace, that card will show you when plex is active on that device, what is playing and you can pause/resume the device… but that’s it.
