Have followed the instructions on github,
ITFFF has been setup correctly. and appears to work and google says the right thing. Howeverr there is no sound from any of the google home devices.
The trace log says
Triggered by the event ‘ifttt_webhook_received’ at 26 June 2022, 17:54:07
Test template condition
Call a service based on a template
Stopped because an error was encountered at 26 June 2022, 17:54:07 (runtime: 0.02 seconds)
Unable to find service plex_assistant.command
Being a noob its a bit confusing what to look at next.
Configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
** - platform: google_translate**
script: !include scripts.yaml
scene: !include scenes.yaml
conversation: #### Keep this line
** intents: #### and this one if you have other intents.**
** Plex:**
** - “Tell Plex to {command}”**
** - “{command} with Plex”**
intent_script: # Keep this line if you have other intent scripts below
** Plex:**
** speech:**
** text: “Command sent to Plex.”**
** action:**
** - service: plex_assistant.command**
** data:**
** command: “{{command}}”**
Regards
