Plex question
Im not sure how to setup plex for HA. I have a local plex server on the same subnet however it is not coming up in HA. I don’t know if i need the plex token. How would i know if i need to add it?
Furthermore, I’ve added the following entry to a separate plex.conf file {“INTERNAL_IP_ADDRESS:INTERNAL_PORT”: {“token”: “null”}}
Thanks for the link however I’ve read that page and still have some questions regarding the syntax.
Additionally, i dont believe i need a network token with my config so I’m not sure what I’m missing.
I had the best luck when I had a instance of a movie playing on Plex and then restarting home assistant.
For me i need to change that
file plex.conf :
{“IP:PORT”: {“token”: “TokenID”}}
To get your token_id
After that in Home Assistant your Plex will be appear.
Good movies to you
