Poer on Home Assitant
Hello there,
I recently purchased a thermostat and thermostatic valve system from POER that has an internal Wifi controller. The control is done through an application called POERSMART.
I would love to have this app and heating control integrated with HA.
Since I am not a programmer, I would love if someone from the HA community could provide some guidance on how to integrate this into HA.
Thanks in advance
The first thing to do is to contact them and ask if they have a documented API (application programming interface). Preferably a local API, not cloud based.
Hello, thank you very much for your answer . Right now I just wrote to you to see if you can provide me with the API. I hope and pray that you can provide it to me because I would like to be able to integrate them since they are thermostats and thermovalves that work very well and have a very good price. If I could integrate them it would be a real wonder. When they answer the email I will tell them to see if they can help me. Thank you very much for everything.
Hi there. They just told me about the POER brand that they don’t give me the platform’s API. So I understand that I can’t integrate it into the home assistant, right ??.
Just tested, it works. Just add Poersmart to hacs, install, reboot and use api key from poersmart app
Closing as now solved with the 3rd party app linked above.
