Populate utility helper with historic data from sensor
I have a sensor for my Bluetti AC300 that tracks lifetime PV input that has been recording data for about a year. This is a cumulative tally that doesn’t reset (unless you reset the AC300 to factory defaults). I recently discovered that I could use the Utility Helper to break this down into daily increments rather than a cumulative running total, so it’s easier to see how much I produce on a daily basis in a bar chart.
But, the Utility Helper only starts populating data from the time you create the helper. Is there any way to use my pre-existing data from the raw sensor data to populate the DB entry the Utility Helper is using so I have have a years worth of data in there instead of just the last 2 days?
Thank you.
Hi Cronix,
I just answered this. Look at this and see if it helps…
