Hi all,
I have a very simple question (I think so, at least).
I have an arduino Uno R3 with MySensors Serial Gateway (running and working). I’m trying to modify the config file as stated in the help but keep getting:
ERROR:mysensors.mysensors:Unable to connect to /dev/ttyACM1
I think the problem is that I don’t know which number I should use after the ACM*. When I run “ls /dev/ tty.*” on the terminal this is the output:
/dev/tty.Bluetooth-Incoming-Port
/dev/tty.usbmodemfd121
/dev/tty.Bluetooth-Modem
The port is usbmodemfd121… but which number should I use in the config file?
Thanks a lot guys, I’m a total newbie and need some helo to start…
