I’m not sure where to create the HA configuration.yaml file. I have a system with Debian 13 + Docker Compose installed, and the Docker config file points to
So, should I create the file in the path HOME/MYUSER/HOMEASSISTANT/CONFIG? Or do the colons at the end of /HOMEASSISTANT have any meaning?
Thank you
You should create it where docker expects it.
The colon is specific to the docker command and separates the volume from the path where the file or directory is mounted in the container.
