Relative NOOB here. However, I’ve got home assistant up and running and using it for a home alarm system.
I noticed that in the code for alarm_control_panel/manual.py, it states the following behavior:
Represents an alarm status.
When armed, will be pending for ‘pending_time’, after that armed.
When triggered, will be pending for ‘trigger_time’. After that will be
triggered for ‘trigger_time’, after that we return to disarmed.
However, the actual behavior displayed is that when the alarm is triggered, it is pending for ‘pending_time’, not for ‘trigger_time’, before changing to state ‘triggered’.
The error appears to be in line 71 of manual.py (alternately, of course, the documentation is incorrect).
I can confirm that the docu is correct so if that is how it is stated in the code it is indeed wrong
The correct behaviour should be to pend for pending_time, then trigger for trigger_time surely?
I would suggest that simply the docs are wrong.
