wbravin
(william bravin)
January 24, 2026, 3:37pm
1
Hello all
I am running HAOS 26.1.2
lately when i go to settings and click on the 3 dots and choose to restart home assistant, home assistant dose restart however the restart pop up does not disappear when HAOS restart nor will it close by pressing X
I need to refresh my internet connection and only then will the popup disappear
How can i fix this?
thank you
mmstano
(Matt Stano)
January 24, 2026, 3:56pm
2
Is it doing this in the companion app, a web browser, or both? Have you tried clearing the cache?
wbravin
(william bravin)
January 24, 2026, 4:27pm
3
Thank you for your very prompt reply
It was doing this via the web browser.
I cleaned as you mentioned the cache and it cleared the issue
again thank you for taking the time from your weekend to respond
Nick4
(Nick)
January 24, 2026, 8:54pm
4
Hi, Good that it got solved!
Tip: if you have a frontend that does not (immediately) respond, it’s good practice to refresh your browser/clear the cache.
Also: please take the time to mark the post that holds the answer.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
this prevents that someone else steps in trying to help
Thanks for giving back to the community!
wbravin
(william bravin)
January 24, 2026, 9:47pm
5
Thank @Nick4 you for this, Gladly
Once i click the 3 dots i do not see the check box
I see heart, copy to link, flag, bookmark and spanner
Nick4
(Nick)
January 24, 2026, 9:59pm
6
Right, this is because you have not added any category to your OP
Please try to keep this in mind since this helps:
you, because you might get help sooner
other members who want to help you since your issue is more clear instead only the title (which to be honest in this case is really very general)
other members with a similar problem
wbravin
(william bravin)
February 3, 2026, 7:16pm
7
Sorry fort my ignorance … What is OP?
