Possible to limit frigate recording times?
hey all im quite new to home assistant and recently installed frigate but as the camera ifs pointing at the driveway towards the car it is getting false readings and recording for at times 55 minutes i have the config set to delete after a day but im wondering if its possible sto set a recording time limit?
I’d work on getting the false trigger worked out first. No sense in engineering your way around a problem from another problem. If you need help, the folks over in the Discord cameras channel are absolutely wonderful.
thanks for the suggestion what server is this in the home assistant server?
Maybe configure “max_disappeared” or “stationary” under “detect” in frigate config
May be able to provide better suggestion if we saw config for the camera
