Possible to manually update zigbee-herdsman-converters?
I have a device which was updated in zigbee-herdsman-converters two weeks ago. I know the converters won’t be integrated into Z2M until the next update.
Is there a way for me to update the converters now instead of waiting for the next update?
Otherwise I’ll shove the device into a drawer and pull it back out when Z2M gets updated.
Yes, you can use an external converter until the next release. See: External converters | Zigbee2MQTT
I think I found my device under here. Is it just as simple as replacing my current file with the one from here?
As per the instructions in the link I posted above:
External converters are stored in data/external_converters folder
Z2M seems to have made quite a few changes to how external converters work
I’m still googling and trying to learn since that folder does not exist
Edit: I think I can copy the code from the updated converter and create my own external converter for the device?
model: 'ZG-205Z/A',
        vendor: 'Tuya',
        description: '5.8Ghz/24Ghz Human presence sensor',
        fromZigbee: [tuya.fz.datapoints],
        toZigbee: [tuya.tz.datapoints],
        exposes: [
            e.presence(),
            e.illuminance().withUnit('lx'),
            e
                .numeric('large_motion_detection_sensitivity', ea.STATE_SET)
                .withValueMin(0)
                .withValueMax(10)
                .withValueStep(1)
                .withUnit('x')
                .withDescription('Motion detection sensitivity'),
            e
                .numeric('large_motion_detection_distance', ea.STATE_SET)
                .withValueMin(0)
                .withValueMax(10)
                .withValueStep(0.01)
                .withUnit('m')
                .withDescription('Motion detection distance'),
            e.enum('motion_state', ea.STATE, ['none', 'small', 'medium', 'large', 'huge', 'gigantic']).withDescription('State of the motion'),
            e
                .numeric('fading_time', ea.STATE_SET)
                .withValueMin(0)
                .withValueMax(28800)
                .withValueStep(1)
                .withUnit('s')
                .withDescription('For how much time presence should stay true after detecting it'),
            e
                .numeric('medium_motion_detection_distance', ea.STATE_SET)
                .withValueMin(0)
                .withValueMax(6)
                .withUnit('m')
                .withDescription('Medium motion detection distance'),
            e
                .numeric('medium_motion_detection_sensitivity', ea.STATE_SET)
                .withValueMin(0)
                .withValueMax(10)
                .withValueStep(1)
                .withUnit('x')
                .withDescription('Medium motion detection sensitivity'),
            e.binary('indicator', ea.STATE_SET, 'ON', 'OFF').withDescription('LED Indicator'),
            e
                .numeric('small_detection_distance', ea.STATE_SET)
                .withValueMin(0)
                .withValueMax(6)
                .withUnit('m')
                .withDescription('Small detection distance'),
            e
                .numeric('small_detection_sensitivity', ea.STATE_SET)
                .withValueMin(0)
                .withValueMax(10)
                .withValueStep(1)
                .withUnit('x')
                .withDescription('Small detection sensitivity'),
        meta: {
            tuyaDatapoints: [
                [1, 'presence', tuya.valueConverter.trueFalse1],
                [2, 'large_motion_detection_sensitivity', tuya.valueConverter.raw],
                [4, 'large_motion_detection_distance', tuya.valueConverter.divideBy100],
                    101,
                    'motion_state',
                    tuya.valueConverterBasic.lookup({
                        none: tuya.enum(0),
                        large: tuya.enum(1),
                        medium: tuya.enum(2),
                        small: tuya.enum(3),
                        huge: tuya.enum(4),
                        gigantic: tuya.enum(5),
                [102, 'fading_time', tuya.valueConverter.raw],
                [104, 'medium_motion_detection_distance', tuya.valueConverter.divideBy100],
                [105, 'medium_motion_detection_sensitivity', tuya.valueConverter.raw],
                [106, 'illuminance', tuya.valueConverter.raw],
                [107, 'indicator', tuya.valueConverter.onOff],
                [108, 'small_detection_distance', tuya.valueConverter.divideBy100],
                [109, 'small_detection_sensitivity', tuya.valueConverter.raw],
                // Not exposed DPs/untested
                // [103, 'motion_false_detection', tuya.valueConverter.raw],
                // [113, 'breathe_false_detection', tuya.valueConverter.raw],
                // [3, 'mov_minimum_distance', tuya.valueConverter.raw],
                // [110, 'micro_minimum_distance', tuya.valueConverter.raw],
                // [111, 'motionless_minimum_distance', tuya.valueConverter.raw],
                // [112, 'reset_setting', tuya.valueConverter.raw],
                // [114, 'time', tuya.valueConverter.raw],
                // [115, 'alarm_time', tuya.valueConverter.raw],
                // [116, 'alarm_volume', tuya.valueConverterBasic.lookup(
                //  {'low': tuya.enum(0), 'medium': tuya.enum(1), 'high': tuya.enum(2), 'mute': tuya.enum(3)})],
                // [117, 'working_mode', tuya.valueConverterBasic.lookup(
                // {'arm': tuya.enum(0), 'off': tuya.enum(1), 'alarm': tuya.enum(2),  'doorbell': tuya.enum(3)})],
                // [118, 'auto1', tuya.valueConverter.raw],
                // [119, 'auto2', tuya.valueConverter.raw],
                // [120, 'auto3', tuya.valueConverter.raw],
Now I just have to figure out how to create the external converter/.js file
