Hi everyone:
I’m trying to set up an Alert in Home Assistant for unavailable entities and I’ve run into a snag with clearing notifications.
I want the alert to work on both my iPhone and the web UI (Persistent Notifications). To get the iPhone to dismiss the notification when the alert is fixed, I’m using “done_message: clear_notification”. The problem is that while the phone clears it perfectly, the web UI just creates a brand new notification that literally says “clear_notification” instead of dismissing the old one.
I tried to fix this by creating a “Notify Group” that points to a script. The script is supposed to look at the message, and if it says “clear_notification”, it calls the dismiss service using a notification_id. Otherwise, it creates the notification. Code below:
alias: Persistent Notifier with Clearing
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ message == 'clear_notification' }}"
sequence:
- data:
notification_id: >-
{{ data.notification_id if data is defined and
data.notification_id is defined else 'generic_alert' }}
action: persistent_notification.dismiss
- conditions:
value_template: "{{ message != 'clear_notification' }}"
sequence:
- action: persistent_notification.create
title: "{{ title }}"
message: "{{ message }}"
notification_id: >-
However, I can’t seem to find a way to add it as a notifier ready to be used by Alert integration.
Has anyone found a clean, generic way to make Persistent Notifications honor the clear command like the mobile app does? I want a solution where I can pass a notification_id through the alert data so I don’t have to write a separate script for every single alert I have.
Any ideas on a better way to do this or how to fix the notify group error? Appreciate your help!
