"Power" attribute as alternative to "Total Energy" for devices in energy dashboard
When adding a device to the energy dashboard, you can only select the “energy total” attribut of the device.
Since Tasmota devices usually loose their daily “total energy” value when they get power-cycled, I would very much appreciate the additional option to select the “power” attribute.
The energy dashobard should be able to accumulate the values and internally generate the “total energy” value for the specific device by itself.
Ofcourse this could also be acomplished by using a script or similar.
A native integration into the energy dashboard would however be a much cleaner solution in my opinion.
Won’t utility meter do what you want?
Don’t forget to vote for your own feature request. :grin:
Closed as incorrect. The energy daashboard can handle periodically resetting energy sensors as long as they have the correct state_class.
