I have set up a wall box under individual in the PFC+. If I query the entities under Template, I get the values. Why is the wallbox not displayed in the PFC+?
Thanks for your help
Haase
Haase
You will probably get more help if you ask here: Power Flow Card Plus 🚀
Sharing the actual config you used helps too.
Also share the yaml. Not a screenshot.
This?
type: custom:power-flow-card-plus
entities:
battery:
entity:
'0': s
'1': e
'2': 'n'
'3': s
'4': o
'5': r
'6': .
'7': w
'8': r
'9': _
'10': h
'11': 'y'
'12': b
'13': r
'14': i
'15': d
'16': _
'17': h
'18': a
'19': l
'20': l
'21': e
'22': _
'23': b
'24': a
'25': t
'26': t
'27': e
'28': r
'29': 'y'
'30': _
'31': p
'32': o
'33': w
'34': e
'35': r
'36': _
'37': c
'38': h
'39': a
'40': r
'41': g
'42': e
'43': _
'44': t
'45': o
'46': t
'47': a
'48': l
production: sensor.wr_hybrid_halle_battery_power_charge_total
consumption: sensor.wr_hybrid_halle_battery_power_discharge_total
state_of_charge: sensor.wr_hybrid_halle_battery_soc_total
grid:
entity:
'0': s
'1': e
'2': 'n'
'3': s
'4': o
'5': r
'6': .
'7': h
'8': o
'9': m
'10': e
'11': _
'12': m
'13': a
'14': 'n'
'15': a
'16': g
'17': e
'18': r
'19': _
'20': h
'21': a
'22': l
'23': l
'24': e
'25': _
'26': m
'27': e
'28': t
'29': e
'30': r
'31': i
'32': 'n'
'33': g
'34': _
'35': p
'36': o
'37': w
'38': e
'39': r
'40': _
'41': s
'42': u
'43': p
'44': p
'45': l
'46': i
'47': e
'48': d
production: sensor.home_manager_halle_metering_power_supplied
secondary_info: {}
solar:
entity: sensor.pv_leistung_halle_ac_2
display_zero_state: true
secondary_info:
entity: sensor.pv_leistung_halle_dc
individual:
- entity: sensor.smaev_3010622455_charging_station_power
secondary_info:
entity: sensor.smaev_3010622455_charging_session_energy
icon: mdi:ev-station
name: eV Charger Halle
unit_of_measurement: W
home:
secondary_info: {}
clickable_entities: true
display_zero_lines:
mode: show
transparency: 50
grey_color:
- 189
- 189
- 189
use_new_flow_rate_model: true
w_decimals: 0
kw_decimals: 1
min_flow_rate: 0.75
max_flow_rate: 6
max_expected_power: 2000
min_expected_power: 0.01
watt_threshold: 1000
transparency_zero_lines: 0
title: PV Anlage Halle
Wow. That config is messed up. Not sure what caused this:
entities:
battery:
'0': s
'1': e
'2': 'n'
'3': s
'4': o
'5': r
'6': .
'7': h
'8': o
'9': m
'10': e
'11': _
'12': m
'13': a
'14': 'n'
'15': a
'16': g
'17': e
'18': r
'19': _
'20': h
'21': a
'22': l
'23': l
'24': e
'25': _
'26': m
'27': e
'28': t
'29': e
'30': r
'31': i
'32': 'n'
'33': g
'34': _
'35': p
'36': o
'37': w
'38': e
'39': r
'40': _
'41': s
'42': u
'43': p
'44': p
'45': l
'46': i
'47': e
'48': d
and this:
grid:
entity:
'0': s
'1': e
'2': 'n'
'3': s
'4': o
'5': r
'6': .
'7': h
'8': o
'9': m
'10': e
'11': _
'12': m
'13': a
'14': 'n'
'15': a
'16': g
'17': e
'18': r
'19': _
'20': h
'21': a
'22': l
'23': l
'24': e
'25': _
'26': m
'27': e
'28': t
'29': e
'30': r
'31': i
'32': 'n'
'33': g
'34': _
'35': p
'36': o
'37': w
'38': e
'39': r
'40': _
'41': s
'42': u
'43': p
'44': p
'45': l
'46': i
'47': e
'48': d
But it should be like this example: GitHub - flixlix/power-flow-card-plus: A power distribution card inspired by the official Energy Distribution card for Home Assistant
I took one from the page and it works. I found, that my “Charger icon” appears only if the chatging power is >0. Do you know where this can be switched off?
THX
Mine did this,
looks like a small bug in the entering data part of the GUI. Just edit the YAML and manually delete all those entitity lines with individual characters and those individual ones will show up
