Power Strip Automation
Hello Guys!,
I’m a newbie in automation. I would like to setup automation to turn off “switch.listwa_biurko” when “load_power” is below 40 Watts. Let me share my automation code:
- id: Turn Off power strip
  alias: Turn Off power strip
  initial_state: 'on'
    platform: numeric_state
    entity_id: switch.listwa_biurko
    value_template: '{{ load_power }}'
    below: 40
    for:
      minutes: 1
    - service: switch.turn_off
Please let me know where I made a mistake here?
The platform is xiaomi_miio
Thank you
Can you post your code with </> button in the text editor.
Done, thanks!
Try this:
  initial_state: 'on'
    value_template: '{{ state.attributes.load_power }}'
    below: 40
    for:
      minutes: 1
The trigger needs to know where in the json dictionary to grab information. providing just ‘load_power’ does not give the trigger the full map to the state you need to grab.
All entitys return a state, example: {{ states.switch.listwa_biurko.state }}
All entitys contain attributes, if you want to access them: {{ states.switch.listwa_biurko.attributes.load_power }} or {{ states.switch.listwa_biurko.attributes[‘load_power’] }}
Inside a trigger, when using a value template and you’ve specified an entity_id, you can just call “state” in your value template to essentially grab {{ states.switch.listwa_biurko }}.
In time you will get used to this crap. Just remember, everything is an object and you’ll always be accessing the state of the object, or an attribute inside the object.
Works perfectly! Thank you very much for the explanation
