Power strip with multiple enpoints EU recommendations
Hello, I am from CZ and i need a power strip which can work in HA. The power strip needs to have like 4 sockets and 2 USB. It have to have 6 endpoints, because i want to switch the usb independently from the power outlets. I saw some lellki zigbee eu power strip on aliexpress, which say they work independent, but i dont know if its true. Can someone give me an advice?
USB ports on most power boards are usually tied to the same power toggle, the power sockets are independent toggles.
Going by the details on this page for that board the USB ports are just always on and not controllable but the power socket ports are:
https://shop.smarthome-europe.com/en/peripheriques/4682-lellki-zigbee-30-connected-power-strip-4-sockets-2-usb-ports.html
I have the useelink matter over wifi based power boards which do have control over the ports but again as a single toggle not individual.
My advice in general is that if you need per device USB toggle then just use the devices USB power adapter via the main power sockets on the board you go with at the time.
Thanks for the advice
