Power strip with six outlets
I did the same thinking as you, and although I physically liked the power strip with a display, I changed the program. Now I use an ESP32 to control the six relays (everything works perfectly), while the ESP32-S3 I use separately from the power strip, with a case I printed myself, and it reads me the on/off values of the six relays. In addition, (in future) it reads me the temperature of the room where the aquarium is located, the temperature of the water, and the PH value.
So I have a small monitor where I can read all the information I need.
Finally, I would like to connect six touch switches to the ESP32-S3 so that I can turn the six power strip sockets on/off while being away from the PC.
Is it possible to control with an ESP32-S3 board the six relays physically connected to other ESP32 board?
I attach below the script with which I read the status of the six relays, hopefully can you help me enter the code part to connect the touch switches and control the six relays
captive_portal:
time:
    platform: homeassistant
    timezone: Europe/Rome
spi:
  clk_pin: GPIO4
  mosi_pin: GPIO5
  # MISO non è usato per il display ST7735S
color:
  - id: my_red
    red: 100%
    green: 3%
    blue: 5%
  - id: my_blu
    red: 5%
    green: 3%
    blue: 100%
  - id: my_green
    red: 5%
    green: 100%
    blue: 3%
  - id: my_yellow
    hex: ffff00
  - id: my_fucsia
    hex: f400a1
  - id: my_orange
    hex: FF8000
display:
  - platform: ili9xxx
    model: ST7796
    spi_id: lcd
    cs_pin: GPIO15
    dc_pin: GPIO7
    reset_pin: GPIO6
    invert_colors: false
    dimensions: 320x480  #320x480 not possible because of memory limitations
    rotation: 90
    color_palette: 8BIT
    #data_rate: 40MHz
    lambda: |-
      it.strftime(3, 3, id(my_font), "%d %b %Y", id(homeassistant_time).now());
      it.strftime(3, 27, id(my_font), "%H:%M:%S", id(homeassistant_time).now());
      it.print(140, 0, id(my_font1), id(my_fucsia), "ACQUARIO:");
      it.print(10, 60, id(my_font), id(my_blu), "FILTRO:");
      if (id(relay_6_status).state) {
        it.print(115, 60, id(my_font), id(my_green), "ON");
      } else {
        it.print(115, 60, id(my_font), id(my_red), "OFF");
      it.print(12, 85, id(my_font), id(my_blu), "ARIA:");
      if (id(relay_1_status).state) {
        it.print(115, 85, id(my_font), id(my_green), "ON");
      } else {
        it.print(115, 85, id(my_font), id(my_red), "OFF");
      it.print(12, 110, id(my_font), id(my_blu), "RISCALD.:");
      if (id(relay_4_status).state) {
        it.print(115, 110, id(my_font), id(my_green), "ON");
      } else {
        it.print(115, 110, id(my_font), id(my_red), "OFF");
      it.print(12, 135, id(my_font), id(my_blu), "LUCI:");
      if (id(relay_5_status).state) {
        it.print(115, 135, id(my_font), id(my_green), "ON");
      } else {
        it.print(115, 135, id(my_font), id(my_red), "OFF");
      it.print(12, 160, id(my_font), id(my_blu), "REFRIG.:");
      if (id(relay_3_status).state) {
        it.print(115, 160, id(my_font), id(my_green), "ON");
      } else {
        it.print(115, 160, id(my_font), id(my_red), "OFF");
      it.print(12, 185, id(my_font), id(my_blu), "AUX:");
      if (id(relay_2_status).state) {
        it.print(115, 185, id(my_font), id(my_green), "ON");
      } else {
        it.print(115, 185, id(my_font), id(my_red), "OFF");
      it.rectangle (5, 55, 160, 160, id(my_green));
font:
  - file: "fonts/arial.ttf"
# Collegamento via API agli switch remoti
switch:
    name: "Relay 1 Remote"
    optimistic: true
    lambda: |-
      return id(relay_1_remote).state;
    name: "Relay 2 Remote"
    optimistic: true
    lambda: |-
      return id(relay_2_remote).state;
    name: "Relay 3 Remote"
    optimistic: true
    lambda: |-
      return id(relay_3_remote).state;
    name: "Relay 4 Remote"
    optimistic: true
    lambda: |-
      return id(relay_4_remote).state;
    name: "Relay 5 Remote"
    optimistic: true
    lambda: |-
      return id(relay_5_remote).state;
    name: "Relay 6 Remote"
    optimistic: true
    lambda: |-
      return id(relay_6_remote).state;
# Componenti remote
binary_sensor:
  - platform: homeassistant
    entity_id: switch.prova_rele_aria
    entity_id: switch.prova_rele_aux
    entity_id: switch.prova_rele_refrigerazione
    entity_id: switch.prova_rele_riscaldatore
    entity_id: switch.prova_rele_luci
    entity_id: switch.prova_rele_filtro
Thanks and ciao
I knew it, you are trying to please your girl friend. "Don’t leave the toilet seat up…blaablaablaaa… " I was wondering how you made it last with 3%. :sweat_smile:
Hey bud, if your lady was named Butch and was 250lb 5’10" you’d do the same! Just dont be telling people or i might lose my Man card!
