Poweropti integration as device/trigger
Hallo all together,
i use since some days HA and i need help for the integration of Poweropti.
I used some codes (yaml) of the forum here and most of them works very well.
I see all the data (current, total consumption and total delivery) also in the energy view.
My problem is that poweropti is not visible as a device. I try to create an automatisation and to use poweropti as a trigger but the poweropti is not visible there (only the other devices)
Has someone a code to use poweropti as a device and to use as a trigger or another idea how i can solve this problem?
Thank you
Vasilis
