Your problem is probably a very minor detail, some character. I see a markdown link in project_id, what is it doing there? I see asterisks. I see rounded quotes in the curl command… “ ” none of that will work.
But I can’t tell which of those things are just side-effects of you copy-pasting here in the forums, or if you really have those issues in your configuration. Double-check every detail…
I think it’s a great card since I’ve been using it. As a newbie to it, and after having done many tests, I can’t find a way to change the size of the text and icons, I say this in case any Guru here could help me. Thanks in advance to everyone.
Thanks for this, I have got the card working but show_card_labels: false doesn’t seem to be working as It seems to be ignored. and the labels are still being displayed.
@Jon_White that option is actually meant to control the card-level labels, not the item-level labels.
I better explain what that means: I figured out that if I create a label filter for a card, so that, for example, it lists only the Urgent tasks, I probably just want to see a label on top, along the card title, saying Urgent, instead of seeing a label with that name in every single item below - not very informative.
The show_card_labels option controls that.
I believe what you’re looking for would be a show_item_labels option, which I don’t currently have!
As an undocumented work-around, any label name that starts with an underscore character will not be shown in the PowerTodoist UI. So if you call your label _secretLabel it won’t show. I realize this is not an ideal solution for many situations, but might help you work around the problem for now.
EDIT: adding a few things here
If all your items have Alexa label, try using that as a filter and then play with the show_card_labels option to get your preferred effect
filter_labels:
- "Alexa"
This makes Alexa a card-level label.
It will be easy for me to add a proper show_item_labels option, and it certainly makes sense to have one. BUT I am on vacation now, I don’t promise anything in the coming two weeks.
I’m afraid I didn’t get back to this project yet, I’ve just been too busy with work. But I still intend to do a bit more work on this card after I finish a couple of work projects.
@Jon_White@HVPereira I just released a new v0.11-beta version with the option requested: show_item_labels (defaults to true).
Now available in HACS
To everyone: I am also announcing that HACS accepted my application (it takes them months) so now you can download my card directly by searching inside HACS, and you can install the card easily from there. It also facilitates upgrades, you get warned and you just need to click to upgrade.
If somebody can please confirm that this works well, I'd appreciate it - I never tried it myself.
Date filtering bugfix
I also fixed a bug breaking date filtering. So @chicknlil25 if you're still having trouble with dates filtering, please try the new version.
@kulnis182 your YAML looks correct to me… what is going wrong, do you get error messages?
Did you do the secrets.yaml part?
If you don’t get errors, if it’s just that you don’t see data in the card, my advice during this initial set up phase is to forget about the card and just check that you see data coming into the sensor, but going into **Developer Tools / States ** and filtering for the sensor name (probably to-do-list).
