PowMr Inverter add-on (via AIRcable MiniP5 TCP bridge) - MQTT discovery, writable priorities, link health
I published a new Home Assistant add-on repository for my HVM6.2M PowMr inverter telemetry/control over an AIRcable MiniP5 TCP bridge. It has 1.2kW solar and a 5kWh battery. My motivation was to automate the battery usage when the kWh is most expensive with a timed use PG&E contract. It switches to battery during these hours and back to grid when power is cheap. The automation does a pretty good job and the installation is very easy using the AIRcable MiniP5. Just an adapter cable and configured to Serial-to-TCP.
Repository:
GitHub - aircable/PowMrAddon: Home Assistant add-on repository for PowMr inverter telemetry/control via AIRcable MiniP5 bridge. ยท GitHub
Add-on:
PowMr Inverter (slug: powmr)
What it does:
  • Polls PowMr inverter data over TCP
  • Publishes MQTT discovery entities to Home Assistant
  • Supports writable inverter priorities (output/charger source priority)
  • Exposes link-health and stale-telemetry diagnostics
  • Includes safe fallback behavior when telemetry is stale
Current release:
v0.1.16
Install:
  1. Home Assistant -> Settings -> Apps (Add-on Store)
  2. Menu (top right) -> Repositories
  3. Add the github link
  4. Install PowMr Inverter
  5. Configure:
    • inverter_host (MiniP5 host/IP)
    • inverter_port (default 3333)
    • poll/stale timing and MQTT options as needed
Notes:
  • Works with amd64 and aarch64
  • MQTT service can be auto-detected from Supervisor
  • Dashboard/automation examples are in the repo docs
Feedback welcome:
  • Issues/bugs: PowMrAddon/issues
  • If you use a different PowMr model/firmware, please share response patterns so compatibility can be expanded.
