I have been searching like a crazy to find a solution here.
I want the switch relay at this device to turn on as default at startup (similar like how you can set a shelly)
But after countless hours scrolling through forums and vibecoding, i still don’t have a working solution.
substitutions:
update_interval: 2s
relay_restore_mode: RESTORE_DEFAULT_ON
esphome:
friendly_name: POW Elite01 20A
# on_boot: # Set the initial state of the template switch to the actual relay state. This will NOT change the state.
# priority: 250.0 # Wait until WiFi is connected to allow the sensor some time to settle
# then:
# - delay: 2s
# - if:
# condition:
# lambda: 'return id(v_sensor).state > 10;'
# then:
# - switch.turn_on: relay_1
# else:
# - switch.turn_off: relay_1
esp32:
board: nodemcu-32s
framework:
type: esp-idf
globals:
- id: relay_last_state
type: bool
restore_value: true
initial_value: 'true'
# Enable logging
logger:
level: INFO
# Enable Home Assistant API
api:
encryption:
key: "4qeZaq8NmGswDHW7sWQmJsMP5SaUIqb4iwBYaCBiRk4="
ota:
- platform: esphome
password: "0fe85abf0e040d649b3412951c53655a"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Powr01 Fallback Hotspot"
password: "8whhDAQ6pnsc"
captive_portal:
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
uart:
rx_pin: GPIO16
baud_rate: 4800
parity: EVEN
time:
- platform: homeassistant
- platform: cse7766
current:
filters:
- throttle_average: ${update_interval}
voltage:
filters:
power:
filters:
on_value_range:
- above: 4.0
then:
- light.turn_on: switch_led
- below: 3.0
then:
- light.turn_off: switch_led
energy:
unit_of_measurement: Wh
device_class: energy
state_class: total_increasing
filters:
- delta: 0.1
- platform: total_daily_energy
name: Total Daily Energy
power_id: w_sensor
filters:
- multiply: 0.001
unit_of_measurement: kWh
- platform: wifi_signal
update_interval: 60s
- platform: uptime
internal: True
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
- platform: internal_temperature
name: "ESP32 Internal Temp"
device_class: power_factor
lambda: |-
if (id(v_sensor).state <= 0 || id(a_sensor).state <= 0) return 0;
return id(w_sensor).state / id(v_sensor).state / id(a_sensor).state;
binary_sensor:
- platform: gpio
pin:
number: GPIO00
ignore_strapping_warning: true
internal: true
filters:
- invert:
- delayed_off: 10ms
on_click:
- max_length: 350ms # short press to toggle the relay
then:
switch.toggle: relay_1
- min_length: 360ms # long press to cycle display info
max_length: 3s
then:
- if:
condition:
binary_sensor.is_on: page
then:
binary_sensor.template.publish:
state: OFF
else:
state: ON
- platform: template # this is a fake sensor to tell the screen which info to show on display
trigger_on_initial_state: true
internal: true
lambda: |-
if (isnan(id(w_sensor).state)) return {};
return id(w_sensor).state > 4;
display:
platform: tm1621
cs_pin: GPIO25
data_pin: GPIO14
read_pin: GPIO26
write_pin: GPIO27
lambda: |-
if (id(page).state) {
it.display_voltage(true);
it.display_kwh(false);
it.printf(0, "%.1f", id(v_sensor).state);
it.printf(1, "%.1f", id(a_sensor).state);
} else {
it.display_voltage(false);
it.display_kwh(true);
it.printf(0, "%.1f", id(wh_sensor).state);
it.printf(1, "%.1f", id(w_sensor).state);
output:
- platform: ledc
pin:
number: GPIO18
inverted: True
switch:
optimistic: true
turn_off_action:
- switch.turn_on: relay_off
turn_on_action:
- switch.turn_on: relay_on
- platform: gpio
restore_mode: ALWAYS_OFF
internal: true
pin: GPIO04
on_turn_on:
- delay: 500ms
- switch.turn_off: relay_off # bi-stable relay so no need to keep on
interlock: [relay_on]
- platform: gpio
internal: true
pin:
number: GPIO02
on_turn_on:
- delay: 500ms
- switch.turn_off: relay_on # bi-stable relay so no need to keep on
interlock: [relay_off]
- platform: restart
text_sensor:
icon: mdi:clock-start
- platform: wifi_info
ip_address:
ssid:
bssid:
light:
- platform: monochromatic
output: led
internal: True
- platform: status_led
internal: True
pin:
number: GPIO05
inverted: True
interval:
- interval: 30s
then:
if:
condition:
wifi.connected:
then:
- light.turn_on: wifi_status_led
else:
- light.turn_off: wifi_status_led
