Added to that, it seems less error prone or more robust. Probably impossible, but still: would there be ay preferenced way of doing this?
same for:
- condition: template
value_template: >
{{ trigger.to_state.state is not none and
trigger.from_state.state is not none and
trigger.to_state.state is in ['home','not_home'] and
trigger.to_state.state is not trigger.from_state.state }}
or
value_template: >
{{ trigger.to_state.state != none and
trigger.from_state.state != none and
trigger.to_state.state != trigger.from_state.state }}
Do whatever you like, both ways of writing this are identical. The startup may take a nanosecond longer on the value template because it has to parse the string.
That can only be in a condition or action because it’s using the trigger object. I’m not even sure why you have the condition like this? There may be a way to check out the trigger type instead of this to_state != None and so forth.
thanks, if been struggling a bit, but am getting closer, thanks to the config checker… (not)
think it should be:
value_template: >
trigger.to_state.state == 'not_home' and
trigger.to_state.state != not trigger.from_state.state }}
at least thats what passes now.
not sure about this:
can i use a condition value_template like this, without stating from: and to: in the trigger? Somehow this seems related, thought is was possible, but some of my templates give me a hard time.
this seems alright (at the moment) and has most uncertainties in it
- alias: Presence Tracking
id: 'Presence Tracking'
- platform: state
entity_id:
- device_tracker.iphone
- device_tracker.telefoon
condition:
value_template: >
value_template: >
{{ (now() - trigger.from_state.last_changed).total_seconds() > 120 }}
value_template: >
{{ is_state('input_boolean.notify_presence', 'on')}}
service: notify.m
data_template:
title: 'Presence Tracking:'
message: >-
{% if trigger.to_state.state == 'not_home' %}
{{ trigger.to_state.attributes.friendly_name }} left {{trigger.from_state.state}}
{% elif trigger.from_state.state == 'not_home' %}
{{ trigger.to_state.attributes.friendly_name }} arrived at {{trigger.to_state.state}}
{% else %}
{{ trigger.to_state.attributes.friendly_name }} left {{trigger.from_state.state}} and arrived at {{trigger.to_state.state}}
{% endif %}
btw found the error typo… at last, after having to disable all my automations and checking them 1 by 1…
value_template: >
forgot to answer you, sorry.
main reason was to prevent the automation from triggering too often, and on wrong triggers (attribute changes trigger the platform: state too, and these phones change attributes very often, apparently especially the iPhones, which disconnect from wifi for battery saving policy.
