Preparing Hassio forever
I decided to install again Hassio on my raspberry pi 3+ on a 64gb SD with proper speeds.
Doesn’t matter the version I tried with versions from actual to 2.8. Ever gets IP, I’m ever able to reach the preparing screen, but never goes far from here even hours later.
Seems stuck on a process and if I check supervisor logs I find errors about fetch version on s3.amazonaws.com.
if I login to Hassio CLI and ping s3.amazomaws.com says it’s alive. If I try to reach same website from browser on my PC o can see lots of information about versions and components.
Also tried as a unraid docker and also stays for ever on preparing with same visual errors on supervisor.
So different versions, on rasp3, on unraid docker,…
What the hell is going on?
No current versions of Hassio Supervisor or Home Assistant start with 2.
Hassio Supervisor is 163. Home Assistant is 0.92.2.
The file when you download the build for your device ( rasp, nuc,… Vmdk,…) Are named like xxxxx-2.11.img.gz that’s what I mean.
I’ve read other posts already and none could solve my issue.
After Install on command line says supervisor 150, HassOs 2.11, channel stable
Are you behind a proxy?
I believe that HA now needs supervisor 163. Perhaps update that via Docker?
I’m not behind proxy and if I try to access to the website on my laptop I can open successful the site.
Tried update the supervisor but gives error.
Been reading another recent posts from another people with similar issue about the preparing Hassio screen.
