Presence detection with LD2410 and BH1750 - i2c doesnt work
I am trying to set up a motion detection based on a D1 mini with a LD2410 and a BH1750 sensor. The LD2410 is connected via the uArt port and the BH1750 should work with the i2c.
This is my config:
esphome:
  friendly_name: Präsenzmelder Wohnzimmer (oben)
esp8266:
  board: d1_mini
# Enable logging
logger:
#  level: DEBUG
#  hardware_uart: UART0_SWAP
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  - platform: esphome
    password: "d"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Motion-Livingroom-Us"
    password: ""
captive_portal:
light:
  - platform: binary
    name: "Blue Status Light"
    output: light_output
    restore_mode: ALWAYS_OFF
output:
  - platform: gpio
    pin: GPIO2
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: true
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
  uart_id: ld2410_uart
  throttle: 1500ms
select:
  - platform: ld2410
    distance_resolution:
      name: distance resolution
    baud_rate:
    out_pin_level:
      name: out pin level
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
number:
  - platform: ld2410
    timeout:
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
text_sensor:
  - platform: ld2410
    version:
      name: "presence sensor version"
    mac_address:
      name: "presence sensor mac address"
switch:
  - platform: ld2410
    engineering_mode:
    bluetooth:
      name: control Bluetooth
  - platform: bh1750
    address: 0x23
    update_interval: 15s
  - platform: ld2410
    moving_distance:
      name: "Moving distance (cm)"
    still_distance:
      name: "Still Distance (cm)"
    moving_energy:
      name: "Move Energy (%)"
    still_energy:
      name: "Still Energy (%)"
    detection_distance:
      name: "Distance Detection (cm)"
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
on my D1 mini I have the LD2410 connected like this:
D1 mini ↔ sensor
RX<->TX (with RX on the D1 beeing GPIO3)
TX<->RX (with TX on the D1 beeing GPIO1)
5V<->VCC
GND<->GND
on my D1 mini I have the BH1750 connected like this:
D1 mini ↔ sensor
D1<->SCL (with D1 on the D1 beeing GPIO5)
D2<->SDA (with D2 on the D1 beeing GPIO4)
3V3<->VCC
GND<->GND
i cant get the BH1750 to work. I already tried 3 different sensors. This is what the log says:
INFO Upload took 35.73 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.178.162 using esphome API
INFO Successfully connected to motion-livingroom-us @ 192.168.178.162 in 35.626s
INFO Successful handshake with motion-livingroom-us @ 192.168.178.162 in 3.619s
[18:08:18][I][app:100]: ESPHome version 2024.8.3 compiled on Oct 28 2024, 18:04:57
[18:08:18][C][wifi:600]: WiFi:
[18:08:18][C][wifi:428]:   Local MAC: 48:55:19:F3:E1:F1
[18:08:18][C][wifi:433]:   SSID: 'Eisprinzessin'[redacted]
[18:08:18][C][wifi:436]:   IP Address: 192.168.178.162
[18:08:18][C][wifi:439]:   BSSID: CC:CE:1E:AC:5F:BE[redacted]
[18:08:18][C][wifi:441]:   Hostname: 'motion-livingroom-us'
[18:08:18][C][wifi:443]:   Signal strength: -42 dB ▂▄▆█
[18:08:18][C][wifi:447]:   Channel: 11
[18:08:18][C][wifi:448]:   Subnet: 255.255.255.0
[18:08:18][C][wifi:449]:   Gateway: 192.168.178.1
[18:08:18][C][wifi:450]:   DNS1: 192.168.178.10
[18:08:18][C][wifi:451]:   DNS2: 0.0.0.0
[18:08:18][C][logger:185]: Logger:
[18:08:18][C][logger:186]:   Level: DEBUG
[18:08:18][C][logger:188]:   Log Baud Rate: 115200
[18:08:18][C][logger:189]:   Hardware UART: UART0
[18:08:18][C][i2c.arduino:071]: I2C Bus:
[18:08:18][C][i2c.arduino:072]:   SDA Pin: GPIO4
[18:08:18][C][i2c.arduino:073]:   SCL Pin: GPIO5
[18:08:18][C][i2c.arduino:074]:   Frequency: 50000 Hz
[18:08:18][C][i2c.arduino:086]:   Recovery: bus successfully recovered
[18:08:18][I][i2c.arduino:096]: Results from i2c bus scan:
[18:08:18][I][i2c.arduino:098]: Found no i2c devices!
[18:08:18][C][uart.arduino_esp8266:118]: UART Bus:
[18:08:18][C][uart.arduino_esp8266:119]:   TX Pin: GPIO1
[18:08:18][C][uart.arduino_esp8266:120]:   RX Pin: GPIO3
[18:08:18][C][uart.arduino_esp8266:122]:   RX Buffer Size: 256
[18:08:18][C][uart.arduino_esp8266:124]:   Baud Rate: 256000 baud
[18:08:18][C][uart.arduino_esp8266:125]:   Data Bits: 8
[18:08:18][C][uart.arduino_esp8266:126]:   Parity: NONE
[18:08:18][C][uart.arduino_esp8266:127]:   Stop bits: 1
[18:08:18][C][uart.arduino_esp8266:129]:   Using hardware serial interface.
[18:08:18][W][uart.arduino_esp8266:143]:   You're using the same serial port for logging and the UART component. Please disable logging over the serial port by setting logger->baud_rate to 0.
[18:08:18][C][gpio.output:010]: GPIO Binary Output:
[18:08:18][C][gpio.output:011]:   Pin: GPIO2
[18:08:18][C][light:103]: Light 'Blue Status Light'
[18:08:18][C][ld2410:022]: LD2410:
[18:08:18][C][ld2410:024]:   TargetBinarySensor 'Presence'
[18:08:18][C][ld2410:024]:     Device Class: 'occupancy'
[18:08:18][C][ld2410:025]:   MovingTargetBinarySensor 'Moving Target'
[18:08:18][C][ld2410:025]:     Device Class: 'motion'
[18:08:18][C][ld2410:026]:   StillTargetBinarySensor 'Still Target'
[18:08:18][C][ld2410:026]:     Device Class: 'occupancy'
[18:08:18][C][ld2410:068]:   EngineeringModeSwitch 'engineering mode'
[18:08:18][C][ld2410:070]:     Icon: 'mdi:pulse'
[18:08:18][C][ld2410:079]:     Device Class: 'switch'
[18:08:18][C][ld2410:090]:     Restore Mode: always OFF
[18:08:18][C][ld2410:068]:   BluetoothSwitch 'control Bluetooth'
[18:08:18][C][ld2410:070]:     Icon: 'mdi:bluetooth'
[18:08:18][C][ld2410:034]:   ResetButton 'factory reset'
[18:08:18][C][ld2410:034]:     Icon: 'mdi:restart-alert'
[18:08:18][C][ld2410:035]:   RestartButton 'restart'
[18:08:18][C][ld2410:035]:     Icon: 'mdi:restart'
[18:08:18][C][ld2410:036]:   QueryButton 'query params'
[18:08:18][C][ld2410:036]:     Icon: 'mdi:database'
[18:08:18][C][ld2410:040]:   MovingTargetDistanceSensor 'Moving distance (cm)'
[18:08:18][C][ld2410:040]:     Device Class: 'distance'
[18:08:18][C][ld2410:040]:     State Class: ''
[18:08:18][C][ld2410:040]:     Unit of Measurement: 'cm'
[18:08:18][C][ld2410:040]:     Accuracy Decimals: 0
[18:08:18][C][ld2410:040]:     Icon: 'mdi:signal-distance-variant'
[18:08:18][C][ld2410:041]:   StillTargetDistanceSensor 'Still Distance (cm)'
[18:08:18][C][ld2410:041]:     Device Class: 'distance'
[18:08:18][C][ld2410:041]:     State Class: ''
[18:08:18][C][ld2410:041]:     Unit of Measurement: 'cm'
[18:08:18][C][ld2410:041]:     Accuracy Decimals: 0
[18:08:18][C][ld2410:041]:     Icon: 'mdi:signal-distance-variant'
[18:08:18][C][ld2410:042]:   MovingTargetEnergySensor 'Move Energy (%)'
[18:08:18][C][ld2410:042]:     State Class: ''
[18:08:18][C][ld2410:042]:     Unit of Measurement: '%'
[18:08:18][C][ld2410:042]:     Accuracy Decimals: 0
[18:08:18][C][ld2410:042]:     Icon: 'mdi:motion-sensor'
[18:08:18][C][ld2410:043]:   StillTargetEnergySensor 'Still Energy (%)'
[18:08:18][C][ld2410:043]:     State Class: ''
[18:08:18][C][ld2410:043]:     Unit of Measurement: '%'
[18:08:18][C][ld2410:043]:     Accuracy Decimals: 0
[18:08:18][C][ld2410:043]:     Icon: 'mdi:flash'
[18:08:18][C][ld2410:044]:   DetectionDistanceSensor 'Distance Detection (cm)'
[18:08:18][C][ld2410:044]:     Device Class: 'distance'
[18:08:18][C][ld2410:044]:     State Class: ''
[18:08:18][C][ld2410:044]:     Unit of Measurement: 'cm'
[18:08:18][C][ld2410:044]:     Accuracy Decimals: 0
[18:08:18][C][ld2410:044]:     Icon: 'mdi:signal-distance-variant'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g0 still energy'
[18:08:18][C][ld2410:046]:     State Class: ''
[18:08:18][C][ld2410:046]:     Unit of Measurement: '%'
[18:08:18][C][ld2410:046]:     Accuracy Decimals: 0
[18:08:18][C][ld2410:046]:     Icon: 'mdi:flash'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g1 still energy'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g2 still energy'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g3 still energy'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g4 still energy'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g5 still energy'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g6 still energy'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g7 still energy'
[18:08:18][C][ld2410:046]:   NthGateStillSesnsor 'g8 still energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g0 move energy'
[18:08:18][C][ld2410:049]:     State Class: ''
[18:08:18][C][ld2410:049]:     Unit of Measurement: '%'
[18:08:18][C][ld2410:049]:     Accuracy Decimals: 0
[18:08:18][C][ld2410:049]:     Icon: 'mdi:motion-sensor'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g1 move energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g2 move energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g3 move energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g4 move energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g5 move energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g6 move energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g7 move energy'
[18:08:18][C][ld2410:049]:   NthGateMoveSesnsor 'g8 move energy'
[18:08:18][C][ld2410:053]:   VersionTextSensor 'presence sensor version'
[18:08:18][C][ld2410:053]:     Icon: 'mdi:chip'
[18:08:18][C][ld2410:054]:   MacTextSensor 'presence sensor mac address'
[18:08:18][C][ld2410:054]:     Icon: 'mdi:bluetooth'
[18:08:18][C][ld2410:058]:   OutPinLevelSelect 'out pin level'
[18:08:18][C][ld2410:058]:     Icon: 'mdi:scale'
[18:08:18][C][ld2410:059]:   DistanceResolutionSelect 'distance resolution'
[18:08:18][C][ld2410:059]:     Icon: 'mdi:ruler'
[18:08:18][C][ld2410:060]:   BaudRateSelect 'baud rate'
[18:08:18][C][ld2410:060]:     Icon: 'mdi:thermometer'
[18:08:18][C][ld2410:064]:   MaxStillDistanceGateNumber 'max still distance gate'
[18:08:18][C][ld2410:064]:     Icon: 'mdi:motion-sensor'
[18:08:18][C][ld2410:064]:     Device Class: 'distance'
[18:08:18][C][ld2410:065]:   MaxMoveDistanceGateNumber 'max move distance gate'
[18:08:18][C][ld2410:065]:     Icon: 'mdi:motion-sensor'
[18:08:18][C][ld2410:065]:     Device Class: 'distance'
[18:08:18][C][ld2410:066]:   TimeoutNumber 'timeout'
[18:08:18][C][ld2410:066]:     Icon: 'mdi:timelapse'
[18:08:18][C][ld2410:066]:     Unit of Measurement: 's'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g0 still threshold'
[18:08:18][C][ld2410:068]:     Icon: 'mdi:motion-sensor'
[18:08:18][C][ld2410:068]:     Unit of Measurement: '%'
[18:08:18][C][ld2410:068]:     Device Class: 'signal_strength'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g1 still threshold'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g2 still threshold'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g3 still threshold'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g4 still threshold'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g5 still threshold'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g6 still threshold'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g7 still threshold'
[18:08:18][C][ld2410:068]:   Still Thresholds Number 'g8 still threshold'
[18:08:18][C][ld2410:071]:   Move Thresholds Number 'g0 move threshold'
[18:08:18][C][ld2410:071]:     Icon: 'mdi:motion-sensor'
[18:08:18][C][ld2410:071]:     Unit of Measurement: '%'
[18:08:18][C][ld2410:071]:     Device Class: 'signal_strength'
[18:08:18][C][ld2410:071]:   Move Thresholds Number 'g1 move threshold'
[18:08:18][C][ld2410:071]:   Move Thresholds Number 'g2 move threshold'
[18:08:18][C][ld2410:071]:   Move Thresholds Number 'g3 move threshold'
[18:08:18][C][ld2410:071]:   Move Thresholds Number 'g4 move threshold'
[18:08:18][C][ld2410:071]:   Move Thresholds Number 'g5 move threshold'
[18:08:18][C][ld2410:071]:   Move Thresholds Number 'g6 move threshold'
[18:08:19][C][ld2410:071]:   Move Thresholds Number 'g7 move threshold'
[18:08:19][C][ld2410:071]:     Icon: 'mdi:motion-sensor'
[18:08:19][C][ld2410:071]:     Unit of Measurement: '%'
[18:08:19][C][ld2410:071]:     Device Class: 'signal_strength'
[18:08:19][C][ld2410:071]:   Move Thresholds Number 'g8 move threshold'
[18:08:19][C][ld2410:075]:   Throttle_ : 1500ms
[18:08:19][C][ld2410:076]:   MAC Address : 73:DE:5A:C9:6E:CD
[18:08:19][C][ld2410:077]:   Firmware Version : 2.04.23022511
[18:08:19][E][ld2410:336]: Error with last command : incorrect Header
[18:08:19][D][text_sensor:064]: 'presence sensor version': Sending state '2.04.23022511'
[18:08:19][D][text_sensor:064]: 'presence sensor mac address': Sending state '73:DE:5A:C9:6E:CD'
[18:08:19][D][sensor:093]: 'Distance Detection (cm)': Sending state 93.00000 cm with 0 decimals of accuracy
[18:08:19][C][bh1750.sensor:118]: BH1750 'Illuminance'
[18:08:19][C][bh1750.sensor:118]:   Device Class: 'illuminance'
[18:08:19][C][bh1750.sensor:118]:   State Class: 'measurement'
[18:08:19][C][bh1750.sensor:118]:   Unit of Measurement: 'lx'
[18:08:19][C][bh1750.sensor:118]:   Accuracy Decimals: 1
[18:08:19][C][bh1750.sensor:119]:   Address: 0x23
[18:08:19][E][bh1750.sensor:121]: Communication with BH1750 failed!
[18:08:19][C][bh1750.sensor:124]:   Update Interval: 15.0s
[18:08:19][E][component:082]:   Component bh1750.sensor is marked FAILED
[18:08:19][C][captive_portal:088]: Captive Portal:
[18:08:19][C][mdns:116]: mDNS:
[18:08:19][C][mdns:117]:   Hostname: motion-livingroom-us
[18:08:19][C][esphome.ota:073]: Over-The-Air updates:
[18:08:19][C][esphome.ota:074]:   Address: motion-livingroom-us.local:8266
[18:08:19][C][esphome.ota:075]:   Version: 2
[18:08:19][C][esphome.ota:078]:   Password configured
[18:08:19][C][safe_mode:018]: Safe Mode:
[18:08:19][C][safe_mode:019]:   Boot considered successful after 60 seconds
[18:08:19][C][safe_mode:021]:   Invoke after 10 boot attempts
[18:08:19][C][safe_mode:022]:   Remain in safe mode for 300 seconds
[18:08:19][C][api:139]: API Server:
[18:08:19][C][api:140]:   Address: motion-livingroom-us.local:6053
[18:08:19][C][api:142]:   Using noise encryption: YES
So it basically looks like the i2c can’t find any devices.
I tried connecting the BH1750 by itself without the rest of the code like:
captive_portal:
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: true
  - platform: bh1750
    address: 0x23
and it works without any issue.
So what is my mistake? Does UArt and i2c dont work together? Do any ports double?
Could anyone hint me in the right direction?
Thank you in advance!
regards,
Markus
Hi Markus,
You may be better off using an esp32 to capture motion, i2s, and uart serial data. The little 8266 in the D1 mini might not be keeping up.
You will also have more pins available and less chance of the board wanting to re-use pins or something. (and more memory for the firmware)
Your sensor definition is missing i2c_id: bus_a.
Thanks for the response
  - platform: bh1750
    address: 0x23
    i2c_id: bus_a
unfortunatly the same error occurs
i will try that, thank you.
I don’t think so. There is a little bit UART going on, and a little bit I2C, nothing that would make an ESP8266 sweat. The problem seems to be that there are no i2c devices found on the bus.
Since the i2c scan doesn’t find any device, there might be issues with your wiring. Maybe SCL/SDA swapped?
Maybe pullup resistors missing?
What happens when you increase the i2c frequency (100, 200, 400kHz)?
Nope, checked and rechecked it alot of times… even rewired it “wrong” to check…
I tried 100, 200 and 400kHz with no change.
What do you mean by that?
In the meantime i did wire up a esp32 and pasted in the same code, changing board and i2c pins and it works…
Maybe it is an issue of the d1_mini or the esp8266 by itself …
Thank you for your help! Using the smaler d1_mini would be nice as a smaler “housing” would be possible.
OK, seems you tried already a lot :slight_smile:
Since I am interested in motion detection anyways, but don’t have a motion sensor yet, I’ll order one now. Either I find a solution, or I will know that an ESP8266 is not enough for this combination of sensors.
Just to get a comparable setup on my side: which LD2410 exactly do you have? AFAIK there are several versions out there.
i have the LD2410C
