Hi there, as the title says, I’m trying to get this to work w/o success. I’m using slightly modified yaml from https://github.com/loopDelicious/home-automation/tree/main/mmwave.
Here is my yaml
esphome:
friendly_name: mmwave
esp32:
board: esp32-c3-devkitm-1
framework:
type: arduino
# Enable logging
logger:
# Randomly-generated 32-byte base64 encoded string
# https://esphome.io/components/api.html#configuration-variables
api:
encryption:
key: "yW2/5uiLiFZV9o2HM3PJapQRyw80FiuJsy4LkczA"
ota:
- platform: esphome
password: "e8534e369064b85574cf714aa8da7"
wifi:
ssid: !secret wifi_ssid
captive_portal:
# https://esphome.io/components/sensor/ld2410.html
ld2410:
uart:
tx_pin: GPIO21
rx_pin: GPIO20
baud_rate: 256000
parity: NONE
stop_bits: 1
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
out_pin_presence_status:
name: Out pin presence status
The log file shows it is connected and running
INFO ESPHome 2025.4.2
INFO Reading configuration /config/esphome/mwave.yaml...
INFO Starting log output from 192.168.1.207 using esphome API
INFO Successfully connected to mmwave @ 192.168.1.207 in 0.096s
INFO Successful handshake with mmwave @ 192.168.1.207 in 0.079s
[03:37:12][I][app:100]: ESPHome version 2025.4.2 compiled on May 18 2025, 03:29:15
[03:37:12][C][wifi:600]: WiFi:
[03:37:12][C][wifi:428]: Local MAC: D8:3B:DA:12:72:15
[03:37:12][C][wifi:433]: SSID: [redacted]
[03:37:12][C][wifi:436]: IP Address: 192.168.1.207
[03:37:12][C][wifi:440]: BSSID: [redacted]
[03:37:12][C][wifi:441]: Hostname: 'mmwave'
[03:37:12][C][wifi:443]: Signal strength: -39 dB ▂▄▆█
[03:37:12][C][wifi:447]: Channel: 7
[03:37:12][C][wifi:448]: Subnet: 255.255.255.0
[03:37:12][C][wifi:449]: Gateway: 192.168.1.1
[03:37:12][C][wifi:450]: DNS1: 192.168.1.1
[03:37:12][C][wifi:451]: DNS2: 0.0.0.0
[03:37:12][C][logger:177]: Logger:
[03:37:12][C][logger:178]: Max Level: DEBUG
[03:37:12][C][logger:179]: Initial Level: DEBUG
[03:37:12][C][logger:181]: Log Baud Rate: 115200
[03:37:12][C][logger:182]: Hardware UART: USB_CDC
[03:37:12][C][uart.arduino_esp32:151]: UART Bus 0:
[03:37:12][C][uart.arduino_esp32:152]: TX Pin: GPIO21
[03:37:12][C][uart.arduino_esp32:153]: RX Pin: GPIO20
[03:37:12][C][uart.arduino_esp32:155]: RX Buffer Size: 256
[03:37:12][C][uart.arduino_esp32:157]: Baud Rate: 115200 baud
[03:37:12][C][uart.arduino_esp32:158]: Data Bits: 8
[03:37:12][C][uart.arduino_esp32:159]: Parity: NONE
[03:37:12][C][uart.arduino_esp32:160]: Stop bits: 1
[03:37:12][C][ld2410:022]: LD2410:
[03:37:12][C][ld2410:024]: TargetBinarySensor 'Presence'
[03:37:12][C][ld2410:024]: Device Class: 'occupancy'
[03:37:12][C][ld2410:025]: MovingTargetBinarySensor 'Moving Target'
[03:37:12][C][ld2410:025]: Device Class: 'motion'
[03:37:12][C][ld2410:026]: StillTargetBinarySensor 'Still Target'
[03:37:12][C][ld2410:026]: Device Class: 'occupancy'
[03:37:12][C][ld2410:027]: OutPinPresenceStatusBinarySensor 'Out pin presence status'
[03:37:12][C][ld2410:027]: Device Class: 'presence'
[03:37:12][C][ld2410:075]: Throttle_ : 1000ms
[03:37:12][C][ld2410:076]: MAC Address :
[03:37:12][C][ld2410:077]: Firmware Version :
[03:37:12][C][captive_portal:089]: Captive Portal:
[03:37:12][C][mdns:116]: mDNS:
[03:37:12][C][mdns:117]: Hostname: mmwave
[03:37:12][C][esphome.ota:073]: Over-The-Air updates:
[03:37:12][C][esphome.ota:074]: Address: mmwave.local:3232
[03:37:12][C][esphome.ota:075]: Version: 2
[03:37:12][C][esphome.ota:078]: Password configured
[03:37:12][C][safe_mode:018]: Safe Mode:
[03:37:12][C][safe_mode:020]: Boot considered successful after 60 seconds
[03:37:12][C][safe_mode:021]: Invoke after 10 boot attempts
[03:37:12][C][safe_mode:023]: Remain in safe mode for 300 seconds
[03:37:13][C][api:140]: API Server:
[03:37:13][C][api:141]: Address: mmwave.local:6053
[03:37:13][C][api:143]: Using noise encryption: YES
But still showing as
So far I’ve played with different
uart:
tx_pin: GPIO21, GPIO20, GPIO4, GPIO2
rx_pin: GPIO20, GPIO21, GPIO5, GPIO3
The results are the same!
Thank you
