Presenting Sonoff SWV water valve to HomeKit
I’ve been using a Sonoff SWV water valve for a while and want it be recognised as a water valve / irrigation accessory via HomeKit bridge.
It currently presents as a switch, which is fine and works in Apple Home, but I’m not able to set a running time in the same way I can with my Eve water valves. The result is that I end up turning it on and forgetting to turn it of…
Where do I start with configuring the switch as a valve and passing that property to Apple Home through HomeKit bridge?
Did you manage to get this sorted?
In case it’s still needed: This can easily be done by modifying the entity of the switch. Just go to Devices & Entities and adjust the settings for the switch entity by changing the Show as option (from Switch to Vent).
After doing this, a new entity will be created with an ID starting with "vent.", and the original "switch." entity will be hidden.
