Preserve YAML formatting and comments when editing automations via UI
Dear Home Assistant developers,
I prefer working with YAML files for my automations due to the flexibility and readability they offer. However, I’m experiencing a significant issue when modifying automations through the UI:
The Problem:
When I edit an automation that was originally written in YAML (with careful formatting, blank lines, and comments) via the UI and save it, all formatting is lost. The automation gets rewritten as a long, unreadable blob without:
Blank lines between different sections
Comments that explain what certain parts do
Proper indentation and structure
Example:
yaml
BEFORE (readable):
alias: “Evening living room lighting”
description: “Turn on lights at sunset”
Sunset trigger
  • platform: sun
    event: sunset
Lighting actions
  • service: light.turn_on
    entity_id: light.living_room_table
    brightness: 200
Slow dimming over 30 minutes
    entity_id: light.living_room_ambient
    brightness: 150
    transition: 1800
AFTER UI edit (unreadable):
alias: Evening living room lighting
description: Turn on lights at sunset
  • platform: sun
    event: sunset
    brightness: 200
    brightness: 150
    transition: 1800
    Consequences:
Automations become difficult to maintain
Comments (and thus context) are lost
Collaboration becomes more challenging
Finding specific components takes more time
Desired Solution:
I would like to propose that the UI respects the existing YAML structure when automations are saved. Ideally:
Preserve blank lines between logical sections
Maintain comments in their original positions
Keep the original indentation where possible
Alternative Solution:
A setting option to choose between “compact YAML” (current behavior) and “readable YAML” (formatted with comments).
This would significantly improve the workflow for many users who utilize both YAML and the UI!
This has been debated forever in the past.
As far as I know it’s not possible, I believe it’s because the yaml is converted to json.
But if you want to make a point about formatting then maybe you should at least format your post correctly using the code block button </b> .
this one has been discussed many times since HA started storing yaml into json-based storage. I believe the OP can find requests in WTH section.
It’s technically possible while not in current version of HA. Requires yaml parser that treats comment blocks as data, instead of reaping them off. Even Petro started mentioning such an option as possible one some months ago.
It’s also when blueprints are imported and any time the system parses the YAML from an outside source.
Annoying but you just have to use work-arounds.
For instance use a lot of aliases in your Automations & scripts, those are saved.
The forum is not the place for feature requests. This is: home-assistant · Discussions · GitHub
However as previously noted this request will not be implemented for technical reasons. So you have two options:
  1. Write in YAML only where you can comment to your heart’s content.
  2. Use the alias option to store comments for every block in the UI editor.
