I have a oil difusser that have ESPHome installed to control it.
My question is, everytime I upgrade or have a power outage the oil diffuser turns on and start to blow out the “steam”.
Is there a way so that it doesn’t turn on at upgrades or power outage and so on?
Karosm
(Karosm)
April 1, 2025, 1:07pm
2
Most likely.
Post your yaml.
Bellow is the code in my yaml file
# Asakuki Oil Diffuser
substitutions:
node_name: "asakuki"
device_name: "Asakuki"
esphome:
name_add_mac_suffix: false
comment: $device_name
esp8266:
board: esp01_1m
wifi:
networks:
- ssid: !secret wifi_ssid
use_address: 192.168.25.59
#Fallback WIFI
ap:
ssid: "$node_name"
#Captive Portal
captive_portal:
# Enable wireless updates
http_request:
verify_ssl: "false"
ota:
platform: esphome
password: !secret ota_pwd
# Enable webserver
web_server:
port: 80
auth:
username: admin
# Enable Home Assistant API
api:
# enable tuya sensor platform
tuya:
binary_sensor:
- platform: "tuya"
name: $device_name out of water
sensor_datapoint: 12
device_class: "problem"
switch:
# Turn the mist on and off
optimistic: true
turn_on_action:
- uart.write: [0x55, 0xAA, 0x00, 0x06, 0x00, 0x05, 0x67, 0x04, 0x00, 0x01, 0x01, 0x77]
turn_off_action:
- uart.write: [0x55, 0xaa, 0x00, 0x06, 0x00, 0x05, 0x67, 0x04, 0x00, 0x01, 0x02, 0x78]
- uart.write: [0x55, 0xaa, 0x00, 0x06, 0x00, 0x05, 0x6e, 0x04, 0x00, 0x01, 0x01, 0x7E]
# VITAL diffuser may crash if not set
uart:
baud_rate: 9600
tx_pin: GPIO1
rx_pin: GPIO3
# Enable logging
logger:
baud_rate: 0
Karosm
(Karosm)
April 2, 2025, 8:34am
4
Just plain template switch, interesting…
I don’t know why it’s switching on boot, default restore should be off.
Try to add this to switch:
restore_mode: disabled
Yes, that did the trick.
Works now, It doesn’t start after I pull the power cable or after I do an update of the code.
Thank you so much.
Karosm
(Karosm)
April 2, 2025, 9:05am
6
You are welcome!
I wonder why Esphome toggles template switch on boot with default restore though…
