Prevent the switch from turning on the light
Hi fellas!
I have a Zemismart Zigbee switch and I would like to know how I can prevent it from turning on during the daytime. I created an automation that accomplishes this, but when I press the button, the light turns on briefly and then shuts off. Is there a way to achieve this without the light flickering?
alias: Nova Automação
description: ""
triggers:
  - trigger: state
    entity_id:
      - switch.interruptor_quarto_casal
    to: "on"
conditions:
  - condition: sun
    before: sunset
    after: sunrise
actions:
  - action: switch.turn_off
    metadata: {}
    data: {}
      entity_id: switch.interruptor_quarto_casal
mode: single
How is the light turned on?
Pressing a wall switch.
I would be very surprised if there was a way to accomplish that. Physical switch must always work IMO.
Unless the switch has a detached mode so it won’t control the light. Then you can create an automation to conditionally turn on the light.
Exactly. If the switch is directly controlling the circuit, there is no way. Otherwise, connect something like a Shelly 1 to the light and a Shelly i4 to the switch. The i4 tells HA simply whether the switch has been flipped. In HA you then decide what to do with that event.
I see, I thought it is like a soft switch, it is just a push button. So I need different circuits so they can be triggered separately. More expensive than I thought.
There might be alternative options. I just wanted to convey the idea.
But, if you have a Shelly i4, then you have 3 more inputs to which you can connect switches to control scenes or other things, to get a bit more value for money.
