Previous MQTT configuration format working, new format not (binary_sensor, climate, sensor, switch)
So, I have problem that on upgrade to 2022.9.x I got msg from HA that current configuration will not be accepted after 2022.12.x release.
The problem is that I have old configuration which I changed to new MQTT format, but after that binary_sensor, climate, sensor and switch stoped working, on test old configuration is working normally but I get this notification, so it is time to change to new format…
Mosquitto broker settings are default:
My devices:
Sonoff TH10, Sonoff TH16, Sonoff POW2 - all have Tasmota 6.6.0 (yea, old, but it’s working as should)
Shelly 4 Pro 4PM (updated to last FW)
Shelly Plus 2PM (updated to last FW)
Shelly TRV (updated to last FW)
Configuration is slightly different as I use:
slika
and then in .yaml I do not need to write mqtt…
So, anybody know if I made some mistake on my configuration file or what the heck is happening? :thinking: PS. Developer tools do not find any mistake…
# BINNARY SENSOR
#ASUS	192.168.3.34	HA	WiFi
    binary_sensor:
      - name: "Shramba"
        state_topic: "wallpanel/mywallpanel/sensor/motion"
        payload_on: '{"value":true}'
        payload_off: '{"value":false}'
        device_class: motion
# Vektiva SMARWI - Podstrešno okno - https://vektiva.com/en/shop/smarwi
# https://community.home-assistant.io/t/window-mechanism-vektiva-smarwi-mqtt-help-needed/156697/10
    binary_sensor:
      - name: Podstrešno okno (stanje)
        state_topic: 'ion/mqtt/%60019449682a/status'
        value_template: >-
          {% if 'pos:c' in value %}
            {{'OFF'}}
          {% else %}
            {{'ON'}}
          {% endif %}
    binary_sensor:
      - name: Kabinet okno (stanje)
        state_topic: 'ion/mqtt/%600194496a13/status'
        value_template: >-
            {{'OFF'}}
          {% else %}
            {{'ON'}}
          {% endif %}
# CLIMATE SENSOR
##                    Shelly TRV                          ##
#192.168.3.74
    climate:
      - name: "Kuhinja (TRV)"
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
        current_temperature_topic: shellies/shellytrv-kuhinja/info
        current_temperature_template: "{{ value_json.thermostats[0].tmp.value }}"
        temperature_command_topic: shellies/shellytrv-kuhinja/thermostat/0/command/target_t
#192.168.3.75
    climate:
      - name: "Dnevna (TRV)"
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
        current_temperature_topic: shellies/shellytrv-dnevna/info
        temperature_command_topic: shellies/shellytrv-dnevna/thermostat/0/command/target_t
#192.168.3.76
    climate:
      - name: "BlazkaEma (TRV)"
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
        current_temperature_topic: shellies/shellytrv-blazkaema/info
        temperature_command_topic: shellies/shellytrv-blazkaema/thermostat/0/command/target_t
#192.168.3.77
    climate:
      - name: "Luka (TRV)"
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
        current_temperature_topic: shellies/shellytrv-luka/info
        temperature_command_topic: shellies/shellytrv-luka/thermostat/0/command/target_t
#192.168.3.78
    climate:
      - name: "Kopalnica (TRV)"
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
        current_temperature_topic: shellies/shellytrv-kopalnica/info
        temperature_command_topic: shellies/shellytrv-kopalnica/thermostat/0/command/target_t
#192.168.3.79
    climate:
      - name: "Spalnica (TRV)"
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
        current_temperature_topic: shellies/shellytrv-spalnica/info
        temperature_command_topic: shellies/shellytrv-spalnica/thermostat/0/command/target_t
# SENSOR
# MQTT, TABLICA, SONOFF, itd..
# TH16 - 192.168.3.92 - Steber
      - name: "Zunaj-T"
        state_topic: "tele/Sonoff-TH16-Steber/SENSOR"
        value_template: '{{ value_json["AM2301"]["Temperature"] }}'
        unit_of_measurement: "°C"
      - name: "Zunaj-V"
        value_template: '{{ value_json["AM2301"]["Humidity"] }}'
        unit_of_measurement: "%"
# TH16 - 192.168.3.93 - Hodnik
      - name: "Hodnik-T"
        state_topic: "tele/Sonoff-TH16-Hodnik/SENSOR"
      - name: "Hodnik-V"
# ASUS tablet HA 192.168.3.34
      - name: "Shramba-L"
        state_topic: "wallpanel/mywallpanel/sensor/light"
        value_template: '{{ value_json.value }}'
        unit_of_measurement: "Lux"
      - name: "HA ASUS tablica"
        state_topic: "wallpanel/mywallpanel/sensor/battery"
        device_class: battery
# POW2 - 192.168.3.94 - Povratna pumpa (Vodostanje)
      - name: "PP-D"
        state_topic: "tele/Sonoff-POW2-PPumpa/SENSOR"
        value_template: "{{value_json['ENERGY'].Today }}"
        qos: 1
        unit_of_measurement: "kWh"
      - name: "PP-1D"
        value_template: "{{value_json['ENERGY'].Yesterday }}"
        qos: 1
      - name: "PP-vseD"
        value_template: "{{value_json['ENERGY'].Total }}"
        qos: 1
        device_class: energy
        state_class: total
      - name: "PP-tW"
        value_template: "{{value_json['ENERGY'].Power }}"
        qos: 1
        unit_of_measurement: "W"
      - name: "PP-tV"
        value_template: "{{value_json['ENERGY'].Voltage }}"
        qos: 1
        unit_of_measurement: "V"
      - name: "PP-tA"
        value_template: "{{value_json['ENERGY'].Current }}"
        qos: 1
        unit_of_measurement: "A"
# TH16 - 192.168.3.95 - Dnevna
      - name: "Dnevna-T"
        state_topic: "tele/Sonoff-TH16-Dnevna/SENSOR"
      - name: "Dnevna-V"
# TH16 - 192.168.3.96 - Kuhinja
      - name: "Kuhinja-T"
        state_topic: "tele/Sonoff-TH16-Kuhinja/SENSOR"
      - name: "Kuhinja-V"
# TH10 - 192.168.3.97 - Vodostanje
      - name: "Vodostanje-T"
        state_topic: "tele/Sonoff-TH10-Vodostanje/SENSOR"
      - name: "Vodostanje-V"
# TH10 - 192.168.3.98 - Spalnica
      - name: "Spalnica-T"
        state_topic: "tele/Sonoff-TH10-Spalnica/SENSOR"
      - name: "Spalnica-V"
# TH10 - 192.168.3.101 - Luka
      - name: "Luka-T"
        state_topic: "tele/Sonoff-TH10-Luka/SENSOR"
      - name: "Luka-V"
# TH10 - 192.168.3.102 - Blažka
      - name: "Blazka-T"
        state_topic: "tele/Sonoff-TH10-Blazka/SENSOR"
      - name: "Blazka-V"
# POW2 - 192.168.3.103 - Pralnica
      - name: "Pralnica-D"
        state_topic: "tele/Sonoff-POW2-Pralnica/SENSOR"
        qos: 1
      - name: "Pralnica-1D"
        qos: 1
      - name: "Pralnica-vseD"
        qos: 1
        state_class: total
      - name: "Pralnica-tW"
        qos: 1
      - name: "Pralnica-tV"
        qos: 1
      - name: "Pralnica-tA"
        qos: 1
# TH10 - 192.168.3.104 - Pralnica
      - name: "Pralnica-T"
        state_topic: "tele/Sonoff-TH10-Pralnica/SENSOR"
      - name: "Pralnica-V"
# TH16 - 192.168.3.105 - Kabinet
      - name: "Kabinet-T"
        state_topic: "tele/Sonoff-TH16-Kabinet/SENSOR"
      - name: "Kabinet-V"
# TH10 - 192.168.3.107 - Kabinet (SCHRACK)
      - name: "SCHRACK-T"
        state_topic: "tele/Sonoff-TH10-SCHRACK/SENSOR"
      - name: "SCHRACK-V"
# TH10 - 192.168.3.111 - Pečica
      - name: "Pecica-T"
        state_topic: "tele/Sonoff-TH10-Pecica/SENSOR"
      - name: "Pecica-V"
# TH16 - 192.168.3.128 - ZunanjaKlet
      - name: "ZunanjaKlet-T"
        state_topic: "tele/Sonoff-TH16-ZunanjaKlet/SENSOR"
        value_template: '{{ value_json["SI7021"]["Temperature"] }}'
      - name: "ZunanjaKlet-V"
        value_template: '{{ value_json["SI7021"]["Humidity"] }}'
# TH16 - 192.168.3.141 - Klet
      - name: "Klet-T"
        state_topic: "tele/Sonoff-TH16-Klet/SENSOR"
      - name: "Klet-V"
# TH16 - 192.168.3.143 - Klet
      - name: "Kurilnica-T"
        state_topic: "tele/Sonoff-TH16-Kurilnica/SENSOR"
      - name: "Kurilnica-V"
# VREMENSKA POSTAJA - Weather Underground
# https://community.home-assistant.io/t/weather-station-data/58489/36
      - name: "Relativna vlažnost"
        state_topic: "weather/outHumidity"
        icon: mdi:water-percent
        value_template: '{{ value | round(0) }}'
      - name: "Pritisk (višinomer)"
        state_topic: "weather/altimeter_mbar"
        icon: mdi:gauge
        unit_of_measurement: "mBar"
      - name: "Pritisk"
        state_topic: "weather/pressure_mbar"
        icon: mdi:gauge
      - name: "Stopnja padavin"
        state_topic: "weather/rainRate_cm_per_hour"
        icon: mdi:umbrella-outline
        unit_of_measurement: "mm/h"
      - name: "Stopnja padavin (zadnja ura)"
        state_topic: "weather/hourRain_cm"
        icon: mdi:umbrella
      - name: "Padavine (danes)"
        state_topic: "weather/rain24_cm"
        icon: mdi:umbrella
        unit_of_measurement: "mm"
      - name: "Temperatura"
        state_topic: "weather/outTemp_C"
        value_template: '{{ value | round(1) }}'
      - name: "Sončno sevanje"
        state_topic: "weather/radiation_Wpm2"
        icon: mdi:radioactive
        unit_of_measurement: "watts/m²"
      - name: "UV"
        state_topic: "weather/UV"
        icon: mdi:sunglasses
        unit_of_measurement: "index"
      - name: "Hitrost vetra"
        state_topic: "weather/windSpeed_kph"
        icon: mdi:weather-windy
        unit_of_measurement: "km/h"
      - name: "Sunek vetra"
        state_topic: "weather/windGust_kph"
        icon: mdi:weather-windy-variant
      - name: "Smer vetra"
        state_topic: "weather/windDir"
        icon: mdi:wind-turbine
        unit_of_measurement: "°"
##                    Shelly TRV Valve                    ##
      - name: Kuhinja (TRV) ventil
        state_topic: 'shellies/shellytrv-kuhinja/info'
        value_template: '{{ value_json.thermostats[0].pos }}'
        unique_id: shellytrv-kuhinja_valve
        unit_of_measurement: '%'
      - name: Dnevna (TRV) ventil
        state_topic: 'shellies/shellytrv-dnevna/info'
        unique_id: shellytrv-dnevna_valve
      - name: BlazkaEma (TRV) ventil
        state_topic: 'shellies/shellytrv-blazkaema/info'
        unique_id: shellytrv-blazkaema_valve
      - name: Luka (TRV) ventil
        state_topic: 'shellies/shellytrv-luka/info'
        unique_id: shellytrv-luka_valve
      - name: Kopalnica (TRV) ventil
        state_topic: 'shellies/shellytrv-kopalnica/info'
        unique_id: shellytrv-kopalnica_valve
      - name: Spalnica (TRV) ventil
        state_topic: 'shellies/shellytrv-spalnica/info'
        unique_id: shellytrv-spalnica_valve
# SWITCH
    switch:
      - name: "Zunaj - steber (luč)"
        tate_topic: "stat/Sonoff-TH16-Steber/POWER"
        command_topic: "cmnd/Sonoff-TH16-Steber/POWER"
        availability_topic: "tele/Sonoff-TH16-Steber/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        payload_available: "Online"
        payload_not_available: "Offline"
        retain: false
    switch:
      - name: "Hodnik (luč)"
        state_topic: "stat/Sonoff-TH16-Hodnik/POWER"
        command_topic: "cmnd/Sonoff-TH16-Hodnik/POWER"
        availability_topic: "tele/Sonoff-TH16-Hodnik/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Povratna pumpa"
        state_topic: "stat/Sonoff-POW2-PPumpa/POWER"
        command_topic: "cmnd/Sonoff-POW2-PPumpa/POWER"
        availability_topic: "tele/Sonoff-POW2-PPumpa/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Dnevna (null)"
        state_topic: "stat/Sonoff-TH16-Dnevna/POWER"
        command_topic: "cmnd/Sonoff-TH16-Dnevna/POWER"
        availability_topic: "tele/Sonoff-TH16-Dnevna/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Kuhinja (vtičnice)"
        state_topic: "stat/Sonoff-TH16-Kuhinja/POWER"
        command_topic: "cmnd/Sonoff-TH16-Kuhinja/POWER"
        availability_topic: "tele/Sonoff-TH16-Kuhinja/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Pečica"
        state_topic: "stat/Sonoff-TH10-Pecica/POWER"
        command_topic: "cmnd/Sonoff-TH10-Pecica/POWER"
        availability_topic: "tele/Sonoff-TH10-Pecica/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Vodostanje (null)"
        state_topic: "stat/Sonoff-TH10-Vodostanje/POWER"
        command_topic: "cmnd/Sonoff-TH10-Vodostanje/POWER"
        availability_topic: "tele/Sonoff-TH10-Vodostanje/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Spalnica - omara (luč)"
        state_topic: "stat/Sonoff-TH10-Spalnica/POWER"
        command_topic: "cmnd/Sonoff-TH10-Spalnica/POWER"
        availability_topic: "tele/Sonoff-TH10-Spalnica/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Luka (null)"
        state_topic: "stat/Sonoff-TH10-Luka/POWER"
        command_topic: "cmnd/Sonoff-TH10-Luka/POWER"
        availability_topic: "tele/Sonoff-TH10-Luka/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Blažka (null)"
        state_topic: "stat/Sonoff-TH10-Blazka/POWER"
        command_topic: "cmnd/Sonoff-TH10-Blazka/POWER"
        availability_topic: "tele/Sonoff-TH10-Blazka/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
# POW2 - 192.168.3.103 - Sušilni/pralni stroji
    switch:
      - name: "Pralnica (razdelilec)"
        state_topic: "stat/Sonoff-POW2-Pralnica/POWER"
        command_topic: "cmnd/Sonoff-POW2-Pralnica/POWER"
        availability_topic: "tele/Sonoff-POW2-Pralnica/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Pralnica (ventilator)"
        state_topic: "stat/Sonoff-TH10-Pralnica/POWER"
        command_topic: "cmnd/Sonoff-TH10-Pralnica/POWER"
        availability_topic: "tele/Sonoff-TH10-Pralnica/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Kabinet (null)"
        state_topic: "stat/Sonoff-TH16-Kabinet/POWER"
        command_topic: "cmnd/Sonoff-TH16-Kabinet/POWER"
        availability_topic: "tele/Sonoff-TH16-Kabinet/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
    switch:
      - name: "Zunanja Klet"
        state_topic: "stat/Sonoff-TH16-ZunanjaKlet/POWER"
        command_topic: "cmnd/Sonoff-TH16-ZunanjaKlet/POWER"
        availability_topic: "tele/Sonoff-TH16-ZunanjaKlet/LWT"
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
##                    Shelly 4 Pro 4PM                    ##
    switch:
      - name: "Shelly Pro 4PM Relay 1"
        unique_id: "shellypro4pm-kabinet-sw1"
        command_topic: "shellypro4pm-kabinet/rpc"
        payload_on: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 0, "on": true}}'
        payload_off: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 0, "on": false}}'
        state_topic: "shellypro4pm-kabinet/status/switch:0"
        value_template: "{{ value_json.output }}"
        state_on: true
        state_off: false
        qos: 1
    switch:
      - name: "Shelly Pro 4PM Relay 2"
        unique_id: "shellypro4pm-kabinet-sw2"
        payload_on: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 1, "on": true}}'
        payload_off: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 1, "on": false}}'
        state_topic: "shellypro4pm-kabinet/status/switch:1"
        state_on: true
        state_off: false
        qos: 1
    switch:
      - name: "Shelly Pro 4PM Relay 3"
        unique_id: "shellypro4pm-kabinet-sw3"
        payload_on: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 2, "on": true}}'
        payload_off: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 2, "on": false}}'
        state_topic: "shellypro4pm-kabinet/status/switch:2"
        state_on: true
        state_off: false
        qos: 1
    switch:
      - name: "Shelly Pro 4PM Relay 4"
        unique_id: "shellypro4pm-kabinet-sw4"
        payload_on: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 3, "on": true}}'
        payload_off: '{"id": 1, "src":"homeassistant", "method": "Switch.Set", "params": {"id": 3, "on": false}}'
        state_topic: "shellypro4pm-kabinet/status/switch:3"
        state_on: true
        state_off: false
        qos: 1
##                    Shelly Plus 2PM                     ##
    switch:
      - name: "Sončni kolektor - R9xHA pumpa"
        unique_id: "shellyplus2pm-centralna-sw1"
        command_topic: "shellyplus2pm-centralna/rpc"
        state_topic: "shellyplus2pm-centralna/status/switch:0"
        state_on: true
        state_off: false
        qos: 1
    switch:
      - name: "Sončni kolektor - Schneider LED"
        unique_id: "shellyplus2pm-centralna-sw2"
        state_topic: "shellyplus2pm-centralna/status/switch:1"
        state_on: true
        state_off: false
        qos: 1
Example how it was before and it was working normally:
binary_sensor.yaml file:
climate.yaml file:
sensor.yaml file:
slika
switch.yaml file:
slika
You need to remove all of the duplicate “binary_sensor:”, “climate:”, “sensor:”, etc.
you only need one of those per section.
so:
# BINNARY SENSOR
    binary_sensor:
      - name: "Shramba"
        value_template: >-
            {{'OFF'}}
          {% else %}
            {{'ON'}}
          {% endif %}
        value_template: >-
            {{'OFF'}}
          {% else %}
            {{'ON'}}
          {% endif %}
etc.
# CLIMATE SENSOR
##                    Shelly TRV                          ##
#192.168.3.74
    climate:
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
#192.168.3.75
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
#192.168.3.76
        min_temp: 4
        max_temp: 31
        temp_step: 1
        modes:
etc
# SENSOR
      - name: "Zunaj-T"
      - name: "Zunaj-V"
      - name: "Hodnik-T"
etc
# SWITCH
    switch:
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
        qos: 1
        payload_on: "ON"
        payload_off: "OFF"
        retain: false
etc
You are simply to say my hero…
I will try today this…
I know that there should be some stupid thing… and it is :grin:
