Print halts upon system restart (OctoPrint)
Hello guys.
I just lost a 4 hours print because I’ve restarted my Home Assistant after some config changes.
Every time the system is restarted (not a host reboot, but I think the result would be the same) the current printing job just stops after OctoPrint component connects to the printer.
Does anyone has this problem too? Anyway to fix it?
Thanks.
Actually I just realized this too.
It seems to be connected with PSU plugin and using Home Assistant to toggle the smart socket.
Because I didn’t have this problem before installing the plugin.
I’ve been bitten twice by the same issue, just filed a bug: Restarting Home Assistant pauses Print · Issue #16 · edekeijzer/OctoPrint-PSUControl-HomeAssistant · GitHub
The initial problem here can’t possibly be caused by my plugin, as it was reported two years before the plugin was created.
As for your issue as wel as @zagi988 , did you read the readme and disable Automatically turn PSU ON in the PSUControl settings?
Yes, that fixed it.
