Trying to add the Schlage integration, when I enter my user ID and password it returns, Unknown Error Occurred. I am using lowercase for my userid.
I saw in another post about running lock_debug.py and this does run login and return my lock info…
What version of Home Assistant Core has the issue?
2025.3.2
What was the last working version of Home Assistant Core?
No response
What type of installation are you running?
Home Assistant Core
Integration causing the issue
Schlage
Link to integration documentation on our website
Here is what I get in the log:
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
First occurred: 1:44:43 PM (1 occurrences)
Last logged: 1:44:43 PM
Error handling request
File “/usr/local/lib/python3.13/site-packages/pyschlage/auth.py”, line 60, in wrapper
resp.raise_for_status()
File “/usr/local/lib/python3.13/site-packages/requests/models.py”, line 1024, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://api.allegion.yonomi.cloud/v1/users/@me
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py”, line 480, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py”, line 569, in _handle
return await handler(request)
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 92, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 83, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 26, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 86, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 242, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 32, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/helpers/http.py”, line 73, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 81, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 222, in post
return await super().post(request, flow_id)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 122, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 341, in async_configure
result = await self._async_configure(flow_id, user_input)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 388, in _async_configure
result = await self._async_handle_step(
flow, cur_step[“step_id”], user_input
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 491, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/components/schlage/config_flow.py”, line 36, in async_step_user
user_id, errors = await self.hass.async_add_executor_job(
_authenticate, username, password
File “/usr/local/lib/python3.13/concurrent/futures/thread.py”, line 59, in run
File “/usr/src/homeassistant/homeassistant/components/schlage/config_flow.py”, line 113, in _authenticate
user_id = auth.user_id
File “/usr/local/lib/python3.13/site-packages/pyschlage/auth.py”, line 109, in user_id
self._user_id = self._get_user_id()
File “/usr/local/lib/python3.13/site-packages/pyschlage/auth.py”, line 113, in _get_user_id
resp = self.request(“get”, “users/@me”)
File “/usr/local/lib/python3.13/site-packages/pyschlage/auth.py”, line 67, in wrapper
raise UnknownError(message) from ex
pyschlage.exceptions.UnknownError: Not Found
