I currently have a wired problem I can not find a point to search for the root cause.
Since I upgraded to 2021.12.6, I have wired issues restarting the server from UI and also checking the config. It always tells me, that it encounters an invalid domain custom_components.nodered and is not restarting. It simply adds this new log entry (counts up the occurences):
Logger: aiohttp.server
Source: loader.py:580
First occurred: 16:41:47 (9 occurrences)
Last logged: 16:54:51
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 181, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 29, in post
errors = await async_check_ha_config_file(request.app["hass"])
File "/usr/src/homeassistant/homeassistant/config.py", line 938, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 129, in async_check_ha_config_file
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 58, in async_get_integration_with_requirements
integration = await async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 566, in async_get_integration
integration = await _async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 580, in _async_get_integration
raise ValueError(f"Invalid domain {domain}")
ValueError: Invalid domain custom_components.nodered
I already updated the companion integration, all node-red palettes and also deactivated all node-red tabs. But the problem still persists. I also could not find a working solution searching through the forums and the web.
